my 2007 a6 3.2l with 252k miles has been giving me throttle body headaches for the last 6 months or so. I started getting random ESP/Traction control lights turning on the dash and the car cutting power to near zero (though still able to hold about 35-40 mph) no matter what the gas pedal position is.
P0121 - Throttle/Pedal Pos.Sensor A Circ. Range/Performance Implausible signal
Intermittent
P0221 - Throttle/Pedal Position Sensor/Switch B Range/Performance Implausible signal
static
P1545 - Throttle valve control system Malfunction Implausible signal
Intermittent
In september i replaced the throttle body with a $150 one from rockauto. Things were fine until November when i started getting codes again. I suspected the new throttle body was too cheap/shitty so I warrantied it and bought a 400$ bosch unit. The Bosch unit was fine for another month until now and i started getting codes/cut power again. Though this week the power cut was less severe, i can accelerate up to about 60 right now, but it feels like doing so at 10%-15% throttle.
Some more research is pointing to a possible harness issue? this TSB I came across:
https://static.nhtsa.gov/odi/tsbs/20...24818-9999.pdf
Before i go and buy an official Audi throttle body, i think i will try to do the TSB above... but looking for any thoughts from you guys that may have been through this.
Cheers for your 2c,
Marko
