Your regulator will need to be changed, as the stock one cannot bypass enough fuel from that pump. As a result, base pressure jumps up, which then can make tuning things a little more of a headache than needed. A stock ecu appreciates a fairly narrow range of base fuel pressure.
As far as the lines, they are 8mm stock. Whether or not that is enough depends on a lot of factors.
The way to know if the line is sufficient size, is measuring fuel pressure post rail, with a pump that you know is sufficient. So on yours, we know your pump is sufficient. Remember to wire it correctly, so you're actually getting what it can put out. From there, you would want to monitor fuel pressure at the end of the rail (where the stock regulator is) via an external sensor, and log it. If pressure drops as boost and rpm increase, you know the line is insufficient. This also will vary depending on the fuel you're using (E85, Methanol, Petrol), and altitude.
Many upgrade rails at lower power than yours because it's relatively easy, not tremendously expensive, and for aesthetics.
