Results 1 to 9 of 9
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    Air suspension retrofit
    Alright ive been steeping on this for a very long time and i need to get other peoples opinions on this…
    Currently have the sport suspension package and its great, but i really really want an air suspension.
    Should i pull the trigger? Is it really worth it? Should i get oem or go with an aftermarket system?
    Also not sure if theres a thread regarding this, i didnt search before i posted this so if there is just link it here.
    Daily -2015 Audi A7 Prestige| 20% rear & 35% front 3M Ceramic IR tints|Custom Alcantara Starlight Headliner|
    Music, Real Estate, and Audi
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    IMO I don't believe the OEM S7 system would be good on an A7.
    If you could somehow get the OEM A7 air system from Europe to work that would be interesting, but I bet a huge undertaking.
    I would think the aftermarket systems would be better suited and more well sorted then trying to figure out how to get the OEM system to work.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    Why OEM? look and see what you can do in the aftermarket world
    Veteran Member Three Rings DoItAllGarage's Avatar
    Oct 29 2013
    WA to ID
    If you decide to switch over to air, I would also vote for aftermarket!
    Veteran Member Three Rings SexualChocolate's Avatar
    Apr 05 2018
    If you need struts, I have some that I never installed. You'd still need management, but this would at least cover the strut portion of what you'd need for aftermarket.
    https://www.bagriders.com/suspension...nsion-kit.html
    That's what I have. Message me if you're interested!
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    Quote Originally Posted by gk1 View Post
    Ok wow TIL theres a euro OEM air suspension for the A. Americans really get cucked with Audis huh
    I saw accuair had a system for the c7, so i was interested in those. Would i be able to vcd my mmi to communicate with my system to lower/raise based on speed?
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    Quote Originally Posted by Valpo A7 View Post
    I thought OEM since there is an OEM system. All signs point to no though.
    Sep 08 2021
    2013 Chevy Tahoe
    Philadelphia, PA
    I’m also not sure how large of a tank i need, air line size, etc. is there somewhere that educates me on all that info?
    Apr 05 2018
    Quote Originally Posted by AudiInMyA7 View Post
    Trying to retrofit the OEM air system is going to be far more of a headache and cost you more money. The OEM system is more limited in terms of adjustability and expansion.
    If you really want to add air, run the Airlift management with an aftermarket strut and call it a day. You'll have more options for replacement parts at a reasonable cost than when the OEM stuff needs to be replaced. And the OEM system is SLOW. Aftermarket is much quicker.
