Results 1 to 7 of 7
    Junior Member Two Rings
    Mar 11 2020
    Southeast
    Mobil 1 5w-40 European Car Formula
    I've done some searching and only found a thread about the 0w-40..... I was wondering if anyone has used the 5w-40 European car formula from Mobil 1. Any experiences with this oil? I have used it before for topping off between oil changes but never used it for a full oil change so wanted to get some feedback.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Quote Originally Posted by Spartan23 View Post
    Not sure that formulation is still available. There may still be some in stores. I believe it was superseded by Mobil 1 0w40 FS European Car Formula. That is what I run. It is VW 00 502/505 and VW 00 503.1 certified. The FS prefix is important. This oil is much different than the previous 5w40 European Formula. Shear/wear protection is greatly improved.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by MSq5 View Post
    The 0w40 FS European formula is the factory recommended oil for our Porsche, and the wife goes 10k between changes on it.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    I use the 0W-40 Euro Formula Mobil-1 for my 3 Audis.
    Veteran Member Three Rings BucDan's Avatar
    Jul 19 2017
    San Diego, CA
    VW 502/505 approved. It'll be just fine as long as you do your oil changes on time.
    The Mobil 1 5W-40 was made to compete against Castrol's 5W-40. Really nothing more to it than that.
    Mar 31 2008
    eS-4
    CAL*SO
    I use 0-40 mobile1 as well and at 125k miles, blackstone said ive got some of the best oil samples around for my chassis/ year. Only negative comment was that they said the oil tends to break down quicker compared to others, but as long as I kept with the 5k oil change all is good.
    Dont forget walmart has a special twice a year (fall/spring) that you get 5qts for around $12 after rebate. Ive been stacking that for years.
    Veteran Member Three Rings Snowmonkey's Avatar
    Apr 27 2018
    Kansas
    I use it to top off between Leichtuf changes. usually only need a half quart every 6 months or so before i do a change
    2013 Phantom Black S4, 6MT, APR Stage 1, Carbon Intake, Canyon Run CR-15, aFe Pro 5R, Sport Diff, B&O, Nav
