Results 1 to 9 of 9
    Dec 07 2021
    Columbia, MD
    How to determine if MagRide shocks are toast
    I have an idea that my mag ride is toast, however I want to know if there is a way to test it prior to bringing it to a dealer, in the weird event that they are actually still good. Can OBD11 be used to check the voltage range or some other such litmus test?
    Veteran Member Four Rings EvoToSQ5's Avatar
    Aug 09 2018
    2017 Audi SQ5
    Leominster, MA
    Easiest would be to see if the shocks are leaking fluid. What issues are you experiencing?
    Dec 25 2004
    Earth
    You need ODIS.
    If the car has 50,000 miles...the dealership will tell you they are bad...
    The fronts tend to go bad before the backs...why? cause of bad roads and bottoming out the fronts.
    Manual method: Remove a mag ride shock from the car and compress it...if it compresses easily and doesnt rebound...its bad.
    If its leaking oil from around the piston chrome...its bad.
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Dealer loves upselling these. Took my 20k mile R8 in for unrelated service and they tried to sell me shocks at almost $4,000 each lol.
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Dec 07 2021
    Columbia, MD
    Quote Originally Posted by EvoToSQ5 View Post
    When I pull into and out of my driveway, mild incline I get bouncing and possibly hitting bump stops, not thudding but it doesn't feel dampened. The most obvious thing I noticed was rear wheel hop on launches and if I am parked on an incline and I go to leave the spot I will feel the weight shift to the rear before actually pulling away, so like a squatting.
    Quote Originally Posted by MikTip View Post
    You need ODIS.
    I am hoping the dealership tells me they are bad actually, I still have about 30 days left on my Carvana warranty and they have so far replaced everything that was bad. They paid for the leaking valve cover and the leaking water pump housing so far.
    Dec 07 2021
    Columbia, MD
    Spoke to the dealership and was told that the last service I had they checked and said the shocks were good, however something is off and I'm not sure what would be causing the squatting in the rear under load.
    Nov 25 2013
    Ottawa
    So I have had the magride calibrated twice with ODIS. Mine is an RS3 with the ESC traction control (not ESP). If I go up a steep hill flat out in 2nd gear the ESC does not flash. Before the calibration the ESC flashed the whole way up the hill. There are a number of other small improvements. In my experience any shocks will show signs of wear in the 3rd year of ownership. To keep the car in "as new" condition one could change out the shocks, but most people simply put up with the wear and often complain of drivetrain slack(or DSG problems). When in fact the drivetrain slack is worn shocks.
    Dec 07 2021
    Columbia, MD
    Turned out my hop and odd rear end behavior was due to a failed Haldex pump, no codes but that is what the dealership determined, replaced and everything seems good now.
    Aug 29 2015
    Delaware
    Quote Originally Posted by BKozS3 View Post
    Thanks for the follow-up!
    Sent from my Pixel 6 using Tapatalk
