Results 1 to 12 of 12
    Junior Member One Ring
    Dec 28 2021
    Atlanta
    Power steering fluid
    Good morning. I was reading a thread here about power steering fluid but I have lost it and can’t find it again. I am struggling with the search function here…. Anyway, if the power steering reservoir says “Use only mineral hydraulic fluid” does that mean don’t use S11, use 7.1 instead?
    Dec 28 2021
    Atlanta
    I should add, I have a 2008 A4 2.9t Quattro. Based on what I read before I hit the wrong button and made it go away, I was expecting to have to buy some expensive synthetic pentosin oil but on the reservoir it says use mineral hydraulic oil. Those are two different things, right?
    Dec 28 2021
    Atlanta
    2.0t, rather
    Established Member Two Rings tigger_78's Avatar
    Oct 30 2013
    FWIW I use Pentosin CHF202 for my 2008 A4 3.2
    2008 A4 3.2 Avant Titanium Ibis White
    2008 A3 3.2 S-Line Ice Silver (for the missus)
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Pentosin CHF 11s is what most use. Genuine Audi fluid is actually cheaper though, and the Pentosin is a synthetic. Chf202 is the older stuff, but pretty sure its sufficient.
    Sent from my LM-G710VM using Audizine Forum mobile app
    Dec 28 2021
    Atlanta
    It is my understanding that cf11s and cf202 are synthetic whereas my reservoir says to use mineral hydraulic oil. That means it’s not synthetic so whatever is left in there would be mixing with the new stuff. The notions about mixing are, well, mixed so I went with the pentosin stuff that is not synthetic. Thanks though, I appreciate the quick replies.
    Account Terminated Four Rings
    Oct 15 2013
    Buy OEM. A friend used synthetic when it clearly said use mineral oil on the cap and it wrecked seals.
    Jan 21 2018
    frackville, pa US
    Quote Originally Posted by esandes View Post
    I had end seals go on 2 different rebuilt racks. One I used chf11s, the other I used genuine fluid. Thing is, there is NO WAY to know thats why his seals went bad. Sometimes they just go..
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    I've been using CH11s for over 12 years now in all my VAG cars, zero issues, the cap says mineral but nothing sold has been a base mineral oil since the 90s, Even dealer stuff is a synthetic hydraulic fluid.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    May 15 2019
    2007 Mercedes C230 Sport, 2006 Chrsler Serbring, 2006 Volvo S60 2.5T, 2006 A4 Quattro 2.0T
    Bellevue, WA
    Quote Originally Posted by Jayz691 View Post
    its the other way around. Chf202 is new and fully compatible and mixable with audi fluid.
    I am running 202 and flushed power steering about 2-3 times in 3 years to get all the old fluild out. Nothing abnormal seen in extracted fluid.
    This is their description.
    "The Pentosin CHF 2.2 is an all purpose high performance synthetic oil based power steering fluid formulated for central hydraulic systems such s power steering, rear axle steering, level control, hydro-pneumatic suspension, and shock absorbers. Compatible with:
    Audi (2006 - 2010)
    Porsche Cayenne (2005 - 2010)
    Saab (2006 - 2010)
    Volkswagen (2006 - 2010)
    Volvo (2002 - 2010)
    NOTE: If vehicle specifications state CHF 7.1, CHF 11S and CHF 202 can be substituted in place of, but not mixed with, CHF 7.1, CHF 11S and CHF 202 are fully compatible and mixable.
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    I bought this 11 years ago for $23 and topped it off just once. Still good I guess. Not sure if these kinds of stuff actually expires. Fluid still has a nice deep green tint.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
    Jan 21 2018
    frackville, pa US
    Quote Originally Posted by Jeevan View Post
    Audi (2006 - 2010)
    Saab (2006 - 2010)
    Volvo (2002 - 2010)
    Yes, I mixed them up. Chf11s is fully synthetic, chf202 is semi-synthtic. But both are cross compatable.,ya can even use either in older cars that use dex 3 ATF, if you completely flush the system. Don't wanna mix it.
