Results 1 to 14 of 14
Thread: 2002 tt quatro
    Junior Member Two Rings
    Sep 10 2012
    new jersey
    2002 tt quatro
    So i picked up a good deal on a mk1 and having problems figuring out why I cant get systems ready for inspection. The car hasnt been driven in 5+ years and has unknown mods. I know for sure that it has a tune and n249 delete. It runs and drives and peaks at 24lbs of boost. I ran vcds and come to the following codes. How would I tackle these problems and just get it ready for inspection in NJ. Also, is there a way to find out what tune this guy put on it? TYIA
    17695 - boost pressure control valve- open circuit
    16716 knock sensor 2. signal too low- intermittent
    18010 power supply terminal 30. voltage too low- intermittent
    Jul 30 2021
    Winchendon
    17695 is likely unplugged. maybe running a manual boost controller for whatever tune it has. you can find this between the airbox and the valve coverup near the firewall.
    16716 and 18010 could be related. you might have a bad connection at the battery or a weak/failing battery.
    Sep 10 2012
    new jersey
    Thank you! This was after I put a red top battery. Do you think that has to do with that?
    Jul 30 2021
    Winchendon
    it could be. try clearing the codes and see if they come back. i doubt that 17695 is related to the battery swap though.
    Sep 10 2012
    new jersey
    So I did some investigating and looks like the previous owner just cut the n249 plug off and didn’t put a resistor. Could this cause a systems not ready? Looks like only 3 are ready. I’ve driven over 300 miles already.
    Jul 30 2021
    Winchendon
    17695 would be related to the N75 valve, not the N249. the N249 is under your intake manifold and the N75 is the one on your intake hose. regardless, if you meant the N75 then yes that would be the cause. however, im more concerned about the fact that it was CUT OFF and not just unplugged. is there a manual boost controller in its place? post some photos if you can, i would be interested in seeing whats been done to the engine bay area.
    Sep 10 2012
    new jersey
    As far as a manual boost controller goes I’m not sure. Also, I don’t know what time he used. It hasn’t been driven in over 5 years and just changed all the fluids.
    Jul 30 2021
    Winchendon
    i downloaded the 2 photos from the drop box and i dont see the wires that you refer to as being cut. i can see the N75 on the forge hose and it looks like its plugged in.
    Sep 10 2012
    new jersey
    On the second picture, in the middle there is a electrical tape bundle
    - - - Updated - - -
    The official code is
    17695
    - Boost Pressure Control Valve (N249)
    P1287
    - 35-00
    - Open Circuit
    Jul 30 2021
    Winchendon
    gotcha. the second pic looks like its of the coil packs. i dont believe the wiring for the N249 is in that section of the harness. i believe the N249 is under the intake manifold so you would have to trace the wiring back from there. you might get lucky and it might just be unplugged. however, i would also peel back the electrical tape on the coil pack harness and find out why its electrical taped in the first place. they make replacement harness sections for that area due to the wires cracking from heat. i think its only like $50 from ECS.
    Senior Member Three Rings usmcfieldmp's Avatar
    May 04 2020
    Fort Worth, TX
    Part of the N249 system connects above the valve cover though - can't remember which sensor it technically is though. I think a lot of people leave it plugged in, but route the vacuum hoses in a loop. I know I have it resistered on my car.
    2002 Audi TT Quattro || Entering Racecar Status | Needs a LOT of love || Project Thread
    2013 Audi S5 || TOTALED ||
    || 1986 Volkswagen GTI || 1997 Dodge Viper GTS || 2005 Chevrolet Cobalt SS ||
    Sep 10 2012
    new jersey
    Resolved. I put a resistor on that cut off wire
    Sep 10 2012
    new jersey
    Just an update for. Found out it’s a unitronic stage1+. I’m not sure why it would disable monitors.
