Results 1 to 3 of 3
    Jan 05 2022
    Indianapolis, IN
    Not beeping when i lock the doors?
    My passenger door recently stopped locking. I went through all the electronics and wiring with a multimeter to find that my door lock actuator was bad. I replaced the actuator and the door finally locks!
    But now the car does not give a "confirmation beep" when i lock the doors using my key fob. I can also hear a clicking noise in the new actuator when i lock the doors. I am getting error codes [Door- 929 Locking module for Central Locking; Front Passenger Side (F221): Implausible Signal] and [Door- 106] (no info). I tested these with a Bluedriver as well (I dont know if that changes anything).
    I have verified all doors are closed (including trunk and hood) and most other minor things that could cause this. ANY INFO HELPS!!!!!
    Active Member One Ring LadyMec's Avatar
    Sep 28 2021
    Colorado Springs
    Check all doors, including hood and trunk. My trunk is usually open when this happens to me.
    Sep 28 2021
    Colorado Springs
    I know you said you checked, but you may have to open and re-close each one. Is the fob what you're using to lock up?
