Results 1 to 16 of 16
    Junior Member One Ring
    Jan 04 2022
    Pennsylvania
    Audi RS4 DRC Replacement Cost
    So I recently noticed one of my metal DRC lines started to leak. Took it to the dealer for them to confirm and turned out I was correct. However, they also found that 3 out of 4 shocks were leaking so they quoted me to replace all 4 shocks, lines, and a repressure. Now here’s the kicker, they told me it was going to cost $17,500 to do everything. I looked around on forums and that price seems absurdly high, even if it’s replacing everything. I don’t intend to go with coils and want to stick with DRC so I’ll most likely just tell them to repressure it and head off to find an Indy shop to fix everything else. I’m based outside Pittsburgh, Pennsylvania so if anyone has good recommendations on shops who do affordable DRC work, let me know. Thanks!
    Junior Member Two Rings
    Sep 22 2007
    Bedford NH
    That’s a comical price. I wouldn’t even have them pressurize it. Unless your extremely low mileage and going for oem resale value, I would seriously consider a good aftermarket set.
    Nov 12 2015
    Oregon
    Either find a new shop or buy some good coilovers. Ohlins/stasis are the bomb if you can find some. Most go with KW v3 and love them.
    That quote is absolutely ridiculous. When I was pricing DRC parts for my RS6, the shocks could be found for a couple hundred each. Around a grand total. Where the extra 16k on the quote came from who knows. Re-pressurizing the system doesnt take that long, nor should it cost more than a couple hundred to do so. They must be quoting on the entire system. Lines and all. Cant see any other way it would cost that much
    Sent from my SM-N960U1 using Tapatalk
    My build log
    May 20 2010
    Quote Originally Posted by VinnysS4 View Post
    Got a source for this for the RS6?
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Nov 12 2015
    Oregon
    https://www.ebay.com/itm/28452394387...1b0b27e4651374
    Here is one source for NEW OEM replacements for cheap. One thing to keep in mind... you'l have to find someone who will charge the system. Most places wont charge a system they didn't install and most wont install customer supplied parts. This is what I ran into. I have seen 2 people recharge the system themselves throughout the years
    My build log
    Jan 04 2022
    Pennsylvania
    The quote was for everything including the lines. The breakdown was around $5500 for labor (which is believable for dealer rates) and $12000 for parts (which is ludicrous in my opinion).
    Jun 15 2017
    Wisconsin
    That’s an absurd price. For $5k you can get 2 way Öhlins TTX’s, which are probably the ultimate setup for most cars.
    2007 Phantom Black RS4. Stasis Öhlins MS, Euro FBSW, Capristo, Wingbacks, Hotchkis ARB, MkII RNSe.
    2013 Daytona Grey Q7 S-Line Prestige.(Retired but in good hands)
    2018 Navarro Blue SQ5 Prestige.
    2020 Daytona Grey SQ7 Prestige.
    Nov 12 2015
    Oregon
    Quote Originally Posted by carlover164 View Post
    Absolutely ridiculous pricing. Even at $100hr, it doesnt take 55 hours to change the shocks out. Less than one day with one tech can have it done. So pay that guy $200hr and it still doesnt cost that much.
    You'll either want to go elsewhere, or switch over to aftermarket suspension. As stated, ohlins makes arguably the best setup you can get for our cars. Period. And it's much cheaper than the quote you got and it will ride better.
    The main problem is that most shops dont have the DRC recharging equipment. So you'll have to find one that does and is familiar with the job.
    Was the DRC overhauled once before?
    My build log
    May 20 2010
    Jan 04 2022
    Pennsylvania
    Yeah that’s the biggest issue right now, no shops near me has to the equipment to fix it. Called like 8 shops and none were willingly to repair it. There’s a shop in New York that has the tools but it’s going to be a good 6-7 hour drive to get there. I have no idea if the system was overhauled at one point. I got the car in 2018 so I assume whoever had the car back in 2010 had the DRC recall done.
    Sep 22 2007
    Bedford NH
    I’ll say it again. Unless you are crazy low mileage and keeping a museum piece, you’re wasting time and money trying to stick with Drc.
    Veteran Member Three Rings bluebull's Avatar
    Aug 28 2014
    2017 R8 Nardo boosted with VF; 2017 SQ5; F250
    Portland, OR
    Ohlins TTX36
    Use the DRC for boat anchor
    TVS1320 APR, TTX36 Ohlins coils, DXD Flywheel + Clutch, JHM Shift Goodies, Euro Sport Reacecloth Seats, 034 mounts, Stern UCA, JHM full (resonated) exhaust with v-band test pipes and HF cats, JHM short shifter, Rotiform 19x10 with 275 PS4S, Fender to ground is 25.5", ceramic coated and PPF.
    Jan 23 2014
    '13 Touareg TDI - '08 RS4 Mug/Ti
    Derby City
    It's quite obvious no one in here has a clue as to how dealerships work, and why they're commonly called stealerships.
    First, the Audi dealership rate is likely north of 200/hr, not 100 as someone suggested.
    Second, they're not buying parts off of ebay, they're getting them from Audi, and as I've discovered, often at a markup over what you can literally order yourself from https://parts.audiusa.com/ (which is the OEM Audi parts shop).
    As a reference, they wanted 2300 give or take to replace both front axles, parts and labor. I obviously did not, bought from FCP and did it myself for under a grand and 3ish hours of my free labor.
    back to the DRC,
    The rear shocks are 735 and 804 each, the fronts are 785 each, and that's from the website, I'm willing to bet your dealer tacked on a mark up for the estimate, and then apply that for whatever other parts they wanted to throw at you, and I can easily see a 16k bill.
    Like others said, it's WAY more cost effective to eliminate DRC, even with OEM non-DRC suspension.
    But, if you insist on fixing it, you need to truly find out what's leaking. If it's just lines, a hydraulic tubing shop could make replacements. If it's the shocks, well, you're in at 2800 dollars just for those.
    That being said, I have my full DRC shock set, pulled at about 84k with zero leaks. Shocks/springs. I need to list those one of these days..
    Junior Member One Ring CAD73's Avatar
    Dec 07 2021
    '08 RS4 Cab, '09 Jeep JK, '20 Jeep JLU Sahara
    MA
    I replaced the entire DRC system at 15k miles, mostly under a warranty that I paid for when I bought the car from Audi Fort Worth. The DRC replacement ended up only costing me just north of $1,500 out of pocket. So my '08 RS4 with 49k miles on it still bone stock today. I wouldn't have done it if I had to pay out of pocket for everything - and if it fails again I'll be going aftermarket, unless I sell the car by then. They quoted me around $11k total at the time I think. That was about six years ago. Given the supply chain issues and inflation, I'm not surprised by the price tag they gave you - even though I agree it's ridiculous.
    Veteran Member Three Rings blubusdrvr's Avatar
    Mar 02 2015
    1970 LT1 Corvette, 2017 A4, 2001 996TT
    Maryland, United States
    Holy Crap! Yeah, scrap that DRC and get a set of coilovers and be done with it. Like others have said Ohlins/Stasis are incredible and KW3's are a close 2nd (and readily available).
    Feb 15 2007
    I had 3 sets of DRC on my RS4 and finally went with Stasis Ohlins after the 3rd set started leaking/ clunking. Its a terrible system. And the device to pressurize it costs $3000-4000 and many dealers don't have it. I assume they are tacking on that price to your quote. I'm all for originality, but no DRC will last more than 5 years. The DRC is pressurized to 7-9 bar (~120 PSI). With that much pressure, the seals weaken with the fluid and the shocks/ lines start to leak. Again, terrible system.
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
