Results 1 to 8 of 8
    Junior Member Two Rings pwise's Avatar
    Jun 18 2020
    Alberta, Canada
    Allroad air suspension issues, again, continually lol
    So, we've been going through an awful cold snap for a week or so (-30 C, or like -22 F) and of course the Allroad has been acting up.
    Went for a drive, everything as normal for a while, but then the air suspension warning light popped on the dash. Didn't notice much else until I got home.
    It looks like the front bags are fully inflated and the rear are near fully deflated, tilting the front of the car way upwards.
    I pulled it into the heated garage and left it to warm up and unfreeze overnight. The next day it was still tilted up. I started it and pressed the button to lower to level 1 (indicator was at 2) and the whole thing lowered while keeping that same front-up back-down angle! Then it went back up when I pressed level 2. But it's not self leveling and the front looks abnormally high at this angle.
    Edit: I should say that the rear bags don't appear to be losing air. They just don't seem to be going up.
    I let it sit for another few days in the heated garage in hopes that whatever was happening was related to the weather. I took it out for a drive to see if it would self level back to normal. But again I got the suspension warning, as well as ABS, traction and a few other dash lights going crazy, including the battery.
    My next step was to go back to the garage. I hooked up the battery charger for a while and then tried to start the car again and raise/lower but no luck now. It sort of sounds like the compressor is running a little louder than usual but nothing is happening either front or back.
    So that's where I'm at now. I was hoping someone here had some expertise to share or advice to offer. I'm at the point where I'm considering just pulling the battery out and parking it at the edge of the driveway until spring. I don't have much room in the garage to work on it at the moment.
    But if there's something relatively simple to try, I'm game.
    I'm not sure if the sensors, compressor, rear bags, or all of the above are the issue. I replaced the front air bags this past spring without any issues. They were operating perfectly all year.
    Any help is appreciated!
    2014 Audi S4 - black optics, sport diff., red interior, IE stage 1, downpipes.
    2003 Audi Allroad 2.7T
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    Quote Originally Posted by pwise View Post
    Check to verify that all (4) level sensors are connected, and linkage arms are intact ...
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    Jul 15 2021
    15 A3 2.0T, 00 A6 2.7T, 13 Tahoe PPV, 95 Fleetwood, 94 Fleetwood, 85 Eldorado, 94 Cougar
    Northern Illinois
    This might not work for you, but I just figured I would mention that I have a complete set of (4) Eibach/Strutmasters coil springs for the Allroad, as well as front sport shocks and A6 hats. If you are interested, send me a PM and I can give you a package deal.
    Quote Originally Posted by 02 A6 2.7T View Post
    You just reminded me that one of these level sensors is broken on the rear of my A6 with non-air suspension. What are mine even for?
    Veteran Member Three Rings AudiNike12's Avatar
    Oct 10 2017
    Sweden
    For the Xenon headlights
    Audi A6 Allroad 2.7T -04
    Audi A6 2.4 Sedan -04
    Audi A6 3.2 Sedan -05
    Audi TT 1.8T -99
    Jun 18 2020
    Alberta, Canada
    Thank you! I was putting off actually crawling around the car out in the cold but you motivated me to just go have a look. Turns out the front passenger linkage arm is snapped in two. Maybe hit a bump or something in the extreme cold.
    Now to find a replacement.
    Nov 19 2006
    Too much crap
    WA
    Check with SteelyS6 to see if he has one from his partout ... he's in Winterpeg ...
    https://www.audizine.com/forum/showt...-partout/page2
    Veteran Member Four Rings SteelyS6's Avatar
    Oct 29 2011
    Winnipeg Manitoba
    I do have one of those arms if needed.
    Sent from my BBF100-2 using Tapatalk
    Jun 18 2020
    Alberta, Canada
    Quote Originally Posted by SteelyS6 View Post
    Awesome! PM'd!
