Sound clip is very brief. See if you can better locate the sound. Our engines do have a normal "ticking" sound from the direct injection high pressure fuel pump. Might be that. The pump is on the passenger front side of the engine for those of us in the US. That is the left or air intake side when facing the engine from the front of the car. That would be the lower left hand corner in the video clip.
If it is more generalized on both banks, tbe fuel injectors also make ticking sounds.
If its coming from the back of the engine at the firewall, that could be timing chain noise. That is normal for a few seconds at start up, but should not be continuous.
Welcome to Audizine!
