Results 1 to 12 of 12
    Established Member Two Rings SlowB8.5's Avatar
    May 18 2021
    Seattle Washington
    Thumbs down Tie Rod and Steering Knuckle snapped? need help
    So I was driving the S4 in the now and hit a patch of ice and slid into a curb, front right wheel impacted, and now the wheel moves independently from the rest of the steering. So if I turn the steering wheel to the right, the wheel does not move. Just went out there this morning and jacked it up and took off the wheel and inspected. The tie rod was hanging down, and it looks to have broken right out of what I think is the steering knuckle, so I took some pictures. It's hard to see but on the end of the tie rod, where its covered in ice is where it was attached to the knuckle. I know I will need a new tie rod, but will I need a new knuckle? Please Help!!
    2012 Audi S4 Prestige
    Apr 08 2014
    Definitely need the knuckle, bearing and hub. Odds are you might also need to go the length of replacing the inner+outer rod ends and possible the rack versus just the tie rod end..
    May 18 2021
    Seattle Washington
    are you sure I need to replace all of that? seems a little excessive.
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    Quote Originally Posted by SlowB8.5 View Post
    Frankly with hitting a curb you’d be lucky if that was all that’s damaged and needs to be replaced.
    If you have the hydraulic rack you may get lucky, but there’s a good chance an impact like this would destroy the electric rack.
    At absolute minimum, you need a new knuckle & tie rod end. Imo no sense in trying to swap your existing hub & bearing over — will be a TON of work due to corrosion from living in a snow environment, and those parts tend to be problematic on these cars anyways. Very good chance you’ll need inner tie rod or other control arm/suspension components.
    2007 Porsche Cayman | 5MT
    Dec 29 2020
    Highland Village, Texas
    The inner tie rod and rack would only need to be replaced if they are damaged (which there is some likelihood). But knuckle, hub/bearing, and outer tie rod are a must.
    May 18 2021
    Seattle Washington
    How would I be able to tell if the rack is broken? Hydraulic I assume as its a 2012.
    Jan 17 2015
    Check for any obvious damage, but if it works as intended when you put it back together, you’re probably fine
    Dec 29 2020
    Quote Originally Posted by Ashtonts View Post
    Listen for grinding noises and/or jumping teeth.
    Get the car on the ground and go full lock to lock. Count how many turns and divide by 2. Then from each lock, come back by that number and you should be in the center with your wheels pointed straight ahead. If it isn’t, you may have a damaged rack.
    May 18 2021
    Seattle Washington
    And If I replace everything on one side of the suspension, will I have to replace everything on the other side?
    Dec 29 2020
    You don’t HAVE to… it all depends on the condition and mileage of the other side. That being said, the only wear items you have listed are the bearing and outer tie rod. If those are tight on the other side, then you should be fine.
    One caveat though, if you snapped the steering knuckle at the outer tie rod, I would bet there is at least one bent control arm if not more. The steering arm on the knuckle is very short compared to the length of a control arm and so there is not a ton of mechanical advantage when force is applied. If there was enough to break that spot, then there was more than enough to bend a control arm or 2… or more.
    You can chance it and just replace what you know to be damaged and then find out on the alignment if everything else is ok.
    This might be a good time to refresh all of your control arms since you will be in there. They are not too pricey if you don’t need/want the 034 stuff.
    Apr 20 2011
    Hackettstown, NJ
    You can get away with replacing just the knuckle. But your inner and outer tie rod are almost certainly bent. You wont know how bad until you get the new knuckle on and see what the steering angle is. Also yes, wheel bearing is likely compromised but if you buy a used knuckle / hub assembly, it'll have the wheel bearing in it that was in the car it was pulled from.
    If you want to make sure you have no problems. Replace all the above. Or take it one step at a time. Or call up insurance and let them total the car.
    2009 Brilliant Black A4 Avant Prestige 2010 S4 Prestige 6MT Swapped - SOLD
    2012 Nogaro Blue A4 Avant Prestige
    2009 Condor Gray A6 Avant Prestige - On daily duty. 240k miles and counting.
    2018 Glacier White RS3 Unitronic Stg 2 ECU / TCU
    May 18 2021
    Seattle Washington
    are the steering knuckles the same on a b8 as a b8.5?
