Originally Posted by
Wadeboston
Not sure what those ‘vertical’ stripes are on the cylinder wall… I hope it is just sludge streaking from the Berryman treatment and not scoring! Should know in 3 weeks if this improves the oil consumption.
Not trying to be the harbinger of doom, but I would stop and check those same pistons ASAP! If the streaks have gone... great. If they are still present or worse...
The problem with this process, I mentioned before, is that the B-12 will remove the carbon... and ALL the oil in the applied area. Cyl walls, Wrist pins and con rod bearings to name a few. I hope it's just streaking too, but personally, I would send a sample of the oil out to Blackstone and make sure you don't have any extreme wear in this segment.
One of the scariest parts of rebuilding a motor for me is the first rotations... when all that oil is in the pan and there is nothing but assembly lube between all those new parts and total destruction. If I did this I would have to top oil the pistons, incrementally hand crank till I felt comfortable that oil was circulating and had coated the walls again and only then I'd crank without plugs to assure max oil circ before adding fuel. It's like hearing... once damaged it doesn't come back. You get one shot. I may be overly cautious, but none of my motors have ever failed for wear issues.
Below is what you are hoping that the B-12 will get out... without any agitation. I picked at the ring and had to physically poke every hole to get it to open... after removing 2mm of solid carbon! I just don't see it happening unless it's aggressive and then it's a trade for cyl damage over consuming oil. I get that it might have boiled, but that was working on the carbon on top of the piston... I don't see it evenly attacking the lowest ring evenly, basically I'd bet it worked only where the 2nd compression ring lets it leak through.
I still have 3 untouched rings with pistons... might be worth it to see just how much carbon it can remove just sitting... and in a ring compressor to mimic a cylinder.
I just keep thinking that if it was this easy, that VAG would have done this over replacing pistons, since it's way cheaper and doesn't take as much time as rebuilding the motor! There is a reason that they didn't!
Hope the outcome is good.
KS
