Hello-
I have a 2005 Audi A4 B6 Cabriolet and the passenger seat does not go forward and back but all other seat controls work. The seat motor makes no noise at all when triggering the switch forward or back, Unfortunately, the seat stopped working in the full forward position blocking access to the front bolts which hold the seat to the floor. I tried looking under the seat where the wires come into the seat but cannot see the wiring block or much of anything, Vagcom shows a 02011-Right Entry Assistance Control Module (J573) 49-00 No Communication.
My guess is that the -Right Entry Assistance Control Module does not impact this issue - or does it. I located the 30 Amp fuse to the seat behind the trim panel on the the right side of the car under the glove box (glove box is out now because the door latch is broken - awaiting parts - separate issue). The fuse is fine and there is 12V to the fuse.
I wanted to check the switch that controls the the forward and backward movement of the seat. I think the trim piece over this switch is held on by the Seat Trim Retainer - any advise as how to remove the trim piece would be appreciated. I believe that the switch can be replaced without removing the seat. Assuming that the switch is ok, is there anything else I should check before removing the seat?
I have read other posts about removing the seat without access to the front bolts holding down the seat. I will try that if I have to but would rather not.
Any further advise would be appreciated.
Thanks
