Results 1 to 9 of 9
    Senior Member Three Rings Blockis's Avatar
    Jul 25 2012
    2007 A4, 2011 Q5
    Boston, MA
    Rear License Plate Bulb Voltage
    This might be a dumb question, but what is the expected voltage across the rear license plate light contacts?
    My battery reads as 12.3v, but the license plate light contacts read at 1.5v - is this good? Should it be 1.5v?
    Both bulbs went out on me and wondering if something weird is happening (ie; wires corroded or broke), but need a sanity check first before I start checking the wiring harness.
    Contacts look clean.
    Paul
    2002 A4 1.8T Quattro | 197k ☠️
    2007 A4 2.0T Quattro | 168k
    2011 Q5 2.0T Quattro | 240k 🔧
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    I would expect 12V but your electrical contacts don't look those for a festoon bulb; maybe a previous owner replaced them with LEDs.
    Feb 12 2018
    Should be 12v as far as I know but the canbus system may stop sending voltage if it detects no feedback voltage (bulb out warning) while the key is on.
    These contacts are the same as mine. The festoon holder is built together with the lens. Long contact arms stick out from the holder/lens to press against these flat contacts.
    Sent from my IN2025 using Tapatalk
    Feb 15 2016
    Cambridge,Ontario
    this rings a bell what mr. J is saying. with the bulb removed it reads really low but with a good bulb its 12 volts. i ran into the same thibg with my sons B7. we ended up putting LED in without the resistor and yup ,, constant bulb out warning... but its all we could find. original units were crazy expensive and housing was melting and cracking anyway.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Senior Member Two Rings HerNameIsBeast's Avatar
    Jun 11 2020
    Detroit
    https://www.ebay.com/itm/2Pcs-LED-Li...-127632-2357-0
    These work extremely well. No errors or anything. Super bright too.
    Sent from my Pixel 4 using Audizine mobile app
    Jul 25 2012
    2007 A4, 2011 Q5
    Boston, MA
    Awesome, thanks for the information! I got new bulbs+housing off ebay from overseas, maybe it's just the actual prong things aren't matching up well, or the new bulb is already shot.
    Paul
    Jun 11 2020
    Detroit
    Quote Originally Posted by Blockis View Post
    It took me a while to get them to sit just right. There was some corrosion on the contacts so I had to clean and bend prongs on the lights. Does it work when you are moving it around? Mine was always on and off at first until I sat it perfectly.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by HerNameIsBeast View Post
    Thanks for the tip , if it gets here will be a good stocking stuffer for my son.
    1976 Yamaha XS 360
    May 15 2019
    2007 Mercedes C230 Sport, 2006 Chrsler Serbring, 2006 Volvo S60 2.5T, 2006 A4 Quattro 2.0T
    Bellevue, WA
    2Packs License Plate Light LED Lamps Replacement for Audi A3 A4 A6 A8 S6 Q7 RS4 RS6 https://www.amazon.com/dp/B07ZCPGFRC...ing=UTF8&psc=1
    Using these error free LEDs of Amazon for d last 1 year. Didn't blow out yet.
