Results 1 to 10 of 10
    Senior Member Three Rings KAMP's Avatar
    Sep 18 2018
    2004 Nissan Murano SE AWD
    Greasing up caliper guide/slide pins..
    I’m looking to remove and grease up my front caliper guide pins.. any clear instructions on this not to damage the pin/boot? From my research they seem to be a one piece boot?
    Either way, for some reason my front passenger brake pad rubs unevenly on the rotor when depressing the pedal at low speeds. Causing an uneven contact sound during each wheel rotation. Especially, when the brakes are cold, but goes away when warmed up or on warmer days(?).. I initially heard this issue on my factory pads in spring, so I know that my replacement Akebonos aren’t the issue.
    I also don’t believe that it’s the rotors, since the issue wasn’t noticeable during the warm summer months and doesn’t seem apparent on warm days at this time either. Kinda odd.
    Nothing appears to be damaged. I am in Cali, so no rust of any kind, but anything below 60 degrees and the sound is noticeable when slowly pressing on the brake pedal a low speeds.
    Either way, I’d like to see if anyone could walk me through removing the boots and pins properly.
    Instagram: @kamp_s4
    2016 AUDI S4 🕹 6MT (B8.5)
    Glacier White | Magma Red
    Sport Diff | B&O | Tech | Blk Opt
    Sep 16 2020
    West Michigan
    I am not sure if the B8S4 has similar brakes as the C7A6. But I simply pushed the pin out with my finger and cleaned the old dried grease with a clean paper towel and some brake cleaner. I then lathered them up with that high temp green brake caliper pin lube and slid them back in place.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    This might sound stupid, but when I did my front pads and rotors I don’t remember the calipers having traditional slide pins. There were just two 13mm bolts holding the caliper together. Maybe I just screwed up but I remember the bolts being totally dry.
    https://www.audizine.com/forum/showt...or-Replacement
    Sep 18 2018
    Quote Originally Posted by sepheroth86 View Post
    Thank you. I assume the pin slides out and the boot is a one piece like I’ve seen pictured in ECS?
    Instagram: @kamp_s4
    Sep 18 2018
    Quote Originally Posted by jsh139 View Post
    You’re correct on the 13mm bolts. The pins appear separate, unlike most where the bolt/pin is a one piece, which gets greased before screwing back in.
    Instagram: @kamp_s4
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by KAMP View Post
    That makes sense. Thought I was going crazy for a minute there.
    Jul 16 2018
    Atlanta
    This is the old guide pins part: https://parts.audiusa.com/p/48597666/8K0698470B.html But the B is disco now and the current C is the same but doesn't include the grease.
    The boot ends sit into the grooves; otherwise they just slide out. I had one that was rough sliding, bit of emery cloth and smooth sliding again.
    Make sure to use a rubber safe grease. I use 3M silicone paste 08946. Sil-glyde is another common. Don't lube the bolt or the inside of the pin. Just the outside of the pin, which is then covered by the boot.
    But I think next time, I'm going to install these pins: https://www.tyrolsport.com/braking/t...tiffening-kit/
    Active Member One Ring captn_0bv10us's Avatar
    Mar 23 2020
    B6 A4 & a custom square body chevy truck
    Galt/CA/USA
    I have the opposite issue mine makes noise when warmed up and no noise when cold also mine feels like it pulsates when stepping on the brake semi-aggressively also does anyone have issues with massive amounts of brake dust it gets everywhere on my b8.5 s4 i also have cross drilled and slotted
    Sep 18 2018
    Quote Originally Posted by Smac770 View Post
    Awesome, thank you for the info. I’ll look into it tomorrow or the day after and hopefully that this fixes it. Hoping it’s not the actual caliper piston that gets stuck. Just weird that it fixes itself and the noise once warmed up.
    Instagram: @kamp_s4
    Oct 06 2021
    TN
    I recently did my front brakes. Along with popping out the guide pins and cleaning / regreasing them, i found that the round guide studs the pads ride on on the caliper bracket were extremely gunked up. I thoroughyly cleaned those along with the pin maintenance and a notchy feel I would get in the brake pedal at times completely disappeared.
