I bought my car, a 2012, with the same mileage as yours. It already had a dual pulley upgrade and tune (among many other upgrades). The clutch line had already been replaced, as well as the slave cylinder but it was the metal one and the action didn't feel right. I also had the clutch issue where the car would ask for the clutch to be pushed in to start even when I had it on the floor. So I replaced the metal slave with the extended slave cylinder and flushed all the fluid for the clutch/brakes. Car starts fine now, and clutch feels better.
That being said, I've noticed that I really need to make sure the clutch is all the way out before I get on the gas, especially in dynamic mode. The clutch will slip if it's not all the way out first. I'm not sure if this is because the clutch is on the way out or is a consequence of the extra power, or maybe a combination of the two. Regardless, it's not slipping at all when the clutch is all the way out and I get on the gas hard, so for now I'm not worried about replacing it. And when I do I'll definitely be replacing with a clutch that can handle the extra HP.
