Results 1 to 22 of 22
    Junior Member Two Rings
    Nov 23 2021
    london ontario canada
    2012 A4 windshield wiper issue
    My windshield wipers stopped working I checked the fuse it’s still good
    Looks like it’s a common problem is it usually the motor that’s the issue ???
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    I just picked up a used wiper linkage assembly with motor off ebay and put it in, takes about 30 minutes. You will need a wiper arm removal tool.
    2019 Audi A4 Quattro Premium Plus | Manhattan Gray | APR Stage 1 | ECS Intercooler Kit
    *goodbye sweet prince* 2009 Audi A4 Quattro Premium | Ibis White | CTS K04 Hybrid | 034 Motorsports HFC | REV9 Intercooler | Ward Performance Tuning
    Visit us on FB @ Audi B9-B9.5 A4 Owners Official Group
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    We had a B6 A4 where one of the wiper arm spindles became seized due to exposure to the elements. Just needed a new linkage assembly, old motor was fine. Easy enough to swap out. --g
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
    Nov 23 2021
    I was able to remove the wipers how do I know if it’s the motor or just the linkage assembly
    Nov 23 2021
    2012 A4 wiper issue
    How do I know if it’s a linkage issue or a motor issue ??
    Veteran Member Three Rings apeck240's Avatar
    Apr 01 2021
    Look at it
    Nov 23 2021
    Should it move freely?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by Franny1978 View Post
    Disconnect the motor from the linkage and see if you can manually move the linkage. Also operate the wiper motor when disconnected and see if the motor turns.
    Also check the wiper motor fuse. (do this first). Brown fuse panel fuse #9 30 amp.
    Senior Member Three Rings A4B8 2.0tfsi's Avatar
    Nov 02 2017
    Sweden
    You obviously have to disconnect the linkage and test the motor.
    2012 A4 B8 Avant 6MT F23L Custom Tune 3" 200 cell DP Sachs Performance Clutch
    Feb 15 2016
    Cambridge,Ontario
    This is common on all Audis once the mileage gets up there..
    Linkage seizes. I disassemble the linkage clean it up and regrease. But they are cheap to replace.
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Active Member Four Rings Nano909's Avatar
    Jul 25 2016
    California
    This happened to me the other day. Putting the wipers into service mode fixed it.
    B8 A4 S-Line | quattro | Ibis White
    Boss500 Kit | Custom WPT Big Turbo Tune
    Rev9 IC | Fuel-It E Sensor
    Macan 345mm Front Calipers | S5 Rear Calipers | EBC Reds
    S4 Rear Valance | S4 Exhaust | RS4 Grille
    My Porsche Macan BBK upgrade thread: https://www.audizine.com/forum/showt...-on-B8-B8-5-A4
    Nov 23 2021
    Replaced the fuse replaced the motor still nothing any other ideas ?
    Nov 23 2021
    Could I have a bad wiper switch ? How common is that
    Feb 15 2016
    Cambridge,Ontario
    Do the wipers work with the hood unlatched on this car ?
    1976 Yamaha XS 360
    Nov 20 2016
    No.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Spawne32 View Post
    No.
    so that might be a clue right ?
    1976 Yamaha XS 360
    Jul 16 2018
    Atlanta
    One would think a simple scan, step 1 for electrically managed operations issues, would point out such things.
    The windshield wiper motor J400 is on a LIN bus with the G397 RLS, managed by the J519. There are probably output tests for the J400 in the J519 (address 09).
    And regarding the stalk, just monitor the measuring values in the J527 (steering controls, address 16) as you manipulate the stalk to see what the J527 is registering and passing to the J519.
    If the car thought the hood latch was open, he should have the hood open warning diagram in the DIS.
    Jul 16 2018
    Atlanta
    Also, running with Nano's comment, using the menu system to put the wipers into service position would bypass the need to evaluate the operation of the stalk.
    Nov 23 2021
    Thanks for all your help on this guys I’m an Audi newbie
    It ended up being the hood sensor even though the hood was closed it was showing open hood which wouldn’t allow the wipers to come on
    Feb 15 2016
    Cambridge,Ontario
    Called it. Lol .
    1976 Yamaha XS 360
    Nov 23 2021
    Called it. Lol .
    Yep I didn't realize that was a safety feature but makes sense
    Thanks guys for all your help
    Feb 15 2016
    Cambridge,Ontario
    i would say more safety from damaging your car. :)
    1976 Yamaha XS 360
