Results 1 to 20 of 20
    Junior Member Two Rings
    Jan 05 2021
    Staying with Summer Tires in Winter?
    I have the Pirelli P-Zero (PZ4) summer tires that came with the car. Where I live (Washington, DC area), we may get snow a couple times a winter, but everything just shuts down and people stay home until it melts a day or two later. It does get below freezing when we have cold spells. I do have another car with all-weather tires I can use if for some reason I need to drive during the rare snowstorm.
    Can I just stick with the summer tires for the winter? I looked on Pirelli's site, but I can't find any technical specs about operating limitations.
    However, on Tire Rack's site, it states this:
    Pirelli's warranty does not cover tires that develop compound cracking due to use in ambient temperatures below 45° Fahrenheit (7° Celsius), so the P Zero (PZ4), like all summer tires, is not intended to be serviced, stored nor driven in near-freezing temperatures, through snow or on ice.
    The temperature thing is the issue. I wouldn't drive my RS6 in snow or ice, and I keep it in a garage that will never get below 45F, but it will indeed get below 45F outside when I'm driving. Also let's say I visit a friend overnight and park outside -- it can easily get to slightly below freezing at night.
    Am I going to face a real issue, especially safety-wise, if I stay with the summer tires?
    Oct 09 2008
    You have reduced traction below 45° as the compound hardens significantly. You also run the risk of damaging the tire.
    The Awesome™
    Veteran Member Three Rings makisupa's Avatar
    Jan 30 2006
    Boston, MA
    I wouldn’t. You will find the traction significantly reduced and you will chew up/damage the tires. I’d grab a set of decent all seasons to pop on there for the winter, even if you’re not gonna be using/pushing the car much. True winters are really soft and will not be cost effective in your case.
    4.2L CFSA swapped 2013 allroad
    plus a bunch of other crap slapped on there
    Dec 18 2011
    Ct
    having on the right tires during a specific season is like wearing the right pair of shoes. You wouldn't wear sandals in the winter months or during inclement weather nor would you wear winter boots in the summer to the beach lol.
    Get the right type of tires during the winter months: A nice set of performance winter tires. Your RS6 will be fully capable in any weather and the piece of mind will go a long long way.
    Senior Member Three Rings gpoulos's Avatar
    Sep 23 2019
    As others have said. Winter tires have less to do with snow and more to do with rubber compliance at specific temperatures which correlates to traction.
    2021 RS6 Avant Nardo Black/Red
    Oct 07 2020
    MIA
    Yep, as everyone else said… If you're driving below around 7℃ you shouldn't be on summer tires, and exposing summer tires to temps close to or below 0℃ runs the risk of them cracking. Winters look great on the RS6, suits the character of the car:
    Jan 05 2021
    Thanks for the advice. My alternative is to switch to all-weather tires permanently. I don't want to be swapping tires twice a year and it's just not that common around here. The Continental ExtremeContact DWS06 Plus seems like the best option.
    Anyone want to buy some P-Zero's with under 8k miles on them?
    Established Member Two Rings Roman8er's Avatar
    Mar 18 2021
    2021 Yamaha R1
    Atco,NJ
    Quote Originally Posted by DMV_Audi View Post
    When I was a teen working at a service station (we provided service, not just gasoline) I remember doing a lot of tire changing in November. Most couldn't afford a spare set of wheels, so onto the Coats machine and off came the summer tires. Don't know how many still swap, but it would be interesting to see if accidents are up in the winter because of poor traction for braking, etc.
    Veteran Member Four Rings FBAnder's Avatar
    Mar 05 2020
    Chicago Metro
    Late to the party but my vote is also that this is a bad idea. I am scheduled to get my winters put on Wednesday and haven't been driving the car since its been well below 40F. Finally took it out today to just drive it a bit (been over a week) but temps were 39/40F which is still less than ideal.
    Jan 11 2021
    Central NJ
    I run A/S year round. The continentals I use are speed rated/ high performance and are good for my daily and occasional spirited driving.
    Veteran Member Three Rings Group_B's Avatar
    Feb 27 2018
    Hartford, CT
    If you do happen to go somewhere when it's dry and then the weather changes while you are busy, my much younger self can attest that summer tires are like slicks in any sort of winter weather.
    Established Member Two Rings Stankia's Avatar
    May 19 2013
    Chicago
    lol, gets a $100k+ high performance car, can't be bothered to switch the tires twice a year. Americans don't deserve the RS6.
    Mar 05 2020
    Chicago Metro
    Quote Originally Posted by Group_B View Post
    Responding for a friend who can second this notion.
    Jan 11 2021
    Central NJ
    Quote Originally Posted by Stankia View Post
    Let's give the benefit of the doubt here. It just might be the OP's first performance car. Audi would do itself a favor to give tire options when ordering. I took delivery of my RS6 on Jan 2, 2021 and promptly replaced the stock summer performance Pirelli tires for Continental high performance A/S tires. But that's because I knew from experience not to run summer performance tires in the cold. Also the stock 22's don't have sufficient sidewall for winter potholes. They look great, but it is a significant risk for me in the NY Metro area as I've posted elsewhere.
    Sep 23 2019
    Quote Originally Posted by FBAnder View Post
    Buy a quickjack and change them yourself.
    Jan 05 2021
    I made an appointment and will be getting all-weather tires installed this coming week.
    I've lived in colder climates where everyone has winter and summer tires, and I had 2 sets of tires for all my vehicles but that's just not common in the DC area as most vehicles have all-weather tires.
    I also own other performance cars, that do have summer tires, but I just don't drive them when it's cold outside and they are in a heated garage. This is my first performance car with summer tires that I also use as a daily driver.
    Mar 05 2020
    Chicago Metro
    Quote Originally Posted by gpoulos View Post
    RS6 is my first Audi that I opted on not doing the winter/summer swaps myself. The 22s are heavy as shit and I would have to haul them up and down a flight of stairs. The 21s for winters are not that much lighter. After doing this once with the 22s after taking delivery and needing to pull the 22s out of the car and bring them down to store for the rest of the winter, I decided I'll spend the money to have them stored at my indie and let them do the swaps in this case.
    Oct 10 2019
    Toronto, Ontario
    Yeah, these 22's are no joke for weight. Plus, loading them in the car, I'm always worried about damaging my wheels or the car.
    My friend owns a mobile wheel change business and he comes to my house to do the swap.
    I literally just call/email/whatsapp him, he comes and does everything and I pay. I don't lift a single thing and I don't even need to leave my house!
    Jul 27 2013
    indianapolis/indiana
    I use belle tire to swap my tires and for 100 bucks they will clean them, tag and bag them and ship them to michigan to store is a climate controlled environment.
    2003 RS6 Apr stage 1 and tiptronic, Apr divertors, Clear bra, Yellow konis SOLD
    2014 S7 Audi exclusive edition 1, Havana black metallic exterior, Havana brown interior, APR stage 1 ECU/TCU, Total Loss Wreck
    2016 RS7 Stage 2, Mythos Black Metallic, SRM/DS1
    2025 RS6 Daytona Grey Pearl, executive package, carbon package, alcantra package, soft close doors, B&O, res delete
    Mar 05 2020
    Chicago Metro
    Quote Originally Posted by dab View Post
    Nice! That is pretty cheap for cleaning and shipping. I have been doing business with my indie for a long, long time so I am happy to pay their storage fee (they don't even offer this to everyone) and for the twice a year swap. It is a very reasonable charge, IMHO.
