So i will try to keep this short and thorough.
I just bought a 2013 S6 from someone who was claiming that the car was running well until their Battery died over night. He went to jump it...using his diesel truck.. and the car would no longer crank after that. Upon inspection, I noticed that when you get into the car, all the interior powers on with one push of the button, then you go to press the brake and hit the start button and the nothing happens, no noises and the car just shuts off.. MMI screen retracts and ignition is powered off as if you didnt have the brake held down and were just trying to turn off the car normally. it Doesn't try to crank or anything. No check engine light on, but I did notice on the Instrument panel screen was kinda freaking out cycling through 2 messages, one of the messages says that if the car was not in park, it can roll, and the other I believe was that the door was open. The messages would not cycle through normally (usually stay visible for 2 -3 seconds) they were flashing through so quick that i almost couldn't read them. When you have the ignition on and press the brake, it doesn't let you shift through the gears to get it into neutral. I was able to access the shift override and was able to get it into neutral, but still wouldn't start.
Has anyone every experienced anything similar or can you point me to the right direction?
My first thoughts are maybe the main battery fuse ( next to the positive battery terminal) blew when jumping the car or maybe there is an issue with the brake itself?
