Results 1 to 6 of 6
    Nov 23 2021
    Stamford
    facelift a3 paddle shifter HELP
    First off wondering if someone with a 2018 a3/s3 can post the coding to their steering colum (16).
    I purchased a custom steering wheel with oem paddle shifters, I havent been able to find coding or anything online for this, they don't work and the left side doesnt light up anymore. I have seen pre facelift install with no issues/coding. Has anyone done this/ can it be done? Ive gone through all the wiring diagrams and see no difference between a tiptronic from factory. They should just plug and play.
    Mar 10 2019
    FL
    Quote Originally Posted by luisestrada1 View Post
    They changed ECM’s on the facelift models and upgrading wheels is no longer plug and play. You need a dealer to code it in
    Nov 23 2021
    Stamford
    Quote Originally Posted by TreizeRXH View Post
    I work at VW, I tried using ODIS just not sure what needs to be changed/coded, unfortunately some of the coding is blocked on there so I tried with OBD eleven but found nothing that supports paddle shifting
    Nov 23 2021
    Stamford
    Just chased more diagrams and found 2018 for sale took vin from that and found coding for steering column is identical, not sure where else to look at this point.
    Junior Member Two Rings Huluis's Avatar
    Jul 14 2020
    Graz
    I had that problem when i retrofitted a FL Steeringwheel in my pFL,there are two different Indexes of the partnumber for the switches,one is for tiptronic the other isnt.I bought 8W0 951 523 F,Index E doesn't support tiptronic.
    It's an Oldschool Hybrid,burns Gasoline and Rubber.
    Nov 23 2021
    Stamford
    I just ordered that part number because the left side stopped lighting up, it’s weird because on the Audi website it says for vehicles w/o tiptronic, I’ll try out the buttons and see if it works
