Results 1 to 9 of 9
    Jun 15 2010
    Chicago
    Questions for those with Bilstein shocks and H&R springs!
    Have some questions for those running the Bilstein B8 shocks with H&R springs. I recently installed these and have a clunking sound going over sudden dips in the road and the ride became a bit harsh with the colder weather. I did some research and now have a few questions.
    1. Does this set up make noises such as clunks going over big dips? Over little things in the road, it is quiet.
    2. Did you have the bump stops trimmed? I installed new ones and didn’t trim them.
    Jul 31 2016
    PA
    Quote Originally Posted by chi123 View Post
    I have an SQ5 but have no such noise. If you didn't cut your bump stops that's likely your problem.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Junior Member Two Rings
    Mar 27 2010
    Glenmoore
    I did not cut my bump stops, and I don’t have such noise. I have H&M’s oe sports w/ b8 shocks. Make sure your bolts are tight would be my suggestion.
    I had to torque down the rear after install because I forgot to torque them. That was the only noise I had.
    Jun 15 2010
    Chicago
    Quote Originally Posted by richsnipe10 View Post
    I did it cut my bump stops, and I don’t have such noise. I have H&M’s oe sports w/ b8 shocks. Make sure your bolts are tight would be my suggestion.
    How much did you trim off? The instructions in the H&R springs said no trimming of the bumper stops were needed but that's with the OEM struts I'm assuming. Bolts should be good. I used all new bolts and remember torqueing everything down.
    2010 Audi S4 GIAC Stage 2 | 2007 Lexus IS350 Supercharged
    Mar 27 2010
    Glenmoore
    Agh, typo. I did NOT cut the bump stops.
    Veteran Member Three Rings Strong Man's Avatar
    Jan 24 2017
    I'm running the setup for almost year - so far no issues, no clunks
    2013 Audi S5 3.0T: Custom Audison with B&O, Quattro Sport Differential, ADS, 7-speed dual-clutch DL501
    Mods: ||ST2: Unitronic ECU + TCU + Ported SC & Throttle||Intake: ESC Kohlefaser Luft ||Exhaust: AWE Touring with Resonated DPs 102mm tips||Susp:CR15, Alu K, H&R OE, H&R R Sway Bar, ECS Drv Mnt Insert Kit ||H&R Spacers: 15F/20R || Brakes: ECS SS Lines, StopTech BBK Creo Slott Rotors F/R, HAWK 5.0 F/R, Motul 600 || etc.
    Veteran Member Three Rings 3.0ss's Avatar
    Jul 26 2019
    S4, Q7, Q5
    Cumming, GA
    I've got B8 shocks and H&R Sports, no clunks or anything. I didn't mess with the bump stops either. Something must not be right with the installation, mines been perfect for well over a year. Look around for loose bolts first, the only clunking issue I've had from the front turned out to be one of the sway bar brackets was slightly loose.
    2010 S4 Prestige 6MT - Brilliant Red | 034 Stage 2 | 034 190mm | Merc HX | Milltek Resonated Exhaust | Gutted/Reinforced Cats | S34 Intake | JXB Short Shifter Kit | AG M580's | Bilstein B8s | H&R Sport Springs
    2018 Q7 Prestige - Orca Black/Cedar Brown Valcona | Luxury Pack | Driver Assistance Pack | Cold Weather Pack | Towing Pack
    2014 Q5 P+ - Lava Gray Pearl | 3.0T | B&O | MMI+
    Senior Member Three Rings S5boxster's Avatar
    Sep 14 2016
    986 boxster
    East Brunswick NJ
    Hey there, I had my b8.5 from 35k to 100k
    Here some areas where it could be coming from.
    Did u change the front upper shock mount ? (034 has street density)
    That usually causes clunks and a lot of people don’t change them as they don’t know about them.
    All front control arms upper and lower Arms
    Front end links
    Engine mounts
    https://store.034motorsport.com/stru...s5-rs5-q5.html
    Jan 11 2018
    1990 VW Corrado
    London, Ontario
    Don't Bilstein B8's have internal bump stops?
