OK, I'm somewhat more confused after doing more research. Bilstein PSS10 kit # 48-251570 officially fits the 8V A3, S3, and RS3. However, other kits like the KW DDC's have two separate P/N's, A3/S3: 39010049 and RS3: 39010055.
Looking at the parts approvals/certifications for the KW kits, you can see that on the RS3 kit the front axle springs are 0.2 mm larger diameter and 5.0 mm taller untensioned height. The rear springs are 0.3 mm SMALLER diameter, with 6 coil winds instead of 8, and an 80 mm SHORTER untensioned height. This leads me to believe that the fronts are not much different, but the rears are. Interesting bit of info, here.
My intuition tells me Bilstein simply doesn't think there's enough of an RS3 market to develop a specific "ridecontrol" kit like KW has with their separate DDC kits. The Bilstein PSS10 kit is likely adjustable enough to handle all 3 vehicles, and Bilstein expects the user to adjust to their preference anyway. With the ridecontrol and DDC kits, there comes 2 or 3 preset modes. These modes likely take many hours of testing for each vehicle application, so Bilstein simply doesn't want to do it.
So let me just state what my intention is with these questions. Like other users, I find the stock fixed suspension too rough for the bad roads and freeways in LA and Orange County. I've already downsized to Neuspeed 18" RSe10's, but it's still not enough for me. I daily drive the car and never intend to track it, but I also have no intention of making the ride permanently as soft as, say, an A3. I'm all about adjustability for the situation. I am also not trying to lower the car. If it's a required byproduct of swapping the suspension, so be it. But I do not want to lower it more than about an inch.
I feel I have narrowed down my options to electronically adjustable coilovers. The Bilstein ridecontrol kit (49-296389) is $2,400, while the KW kit (39010055) is $3,700. I just can't justify spending an extra $1,300 just because the company says it's officially specific for the RS3.
I guess I'm open to mechanically adjustable kits like the Bilstein PSS10 or KW V3, but I think I will be upset if I don't have the ability to adjust on the fly.
