Code:
OBDeleven data log Date: 2021-11-21 16:02 VIN: WAUBGxxxxxxxxxx Car: Audi S4 Year: 2010 Body type: Saloon Engine: CCBA Mileage: 247520 KM --------------------------------------------------------------- 01 Engine System description: 3.0T SIMOS84 Software number: 8K0907551D Software version: 0003 Hardware number: 8K0907551A Hardware version: H06 ODX name: EV_ECM30TFS0218K0907551D ODX version: 001003 Long coding: 0104000A240F0128 Trouble codes: P10A400 - Regulating flap for intake air Mechanical malfunction Intermittent Date: 2021-11-20 14:42:19 Mileage: 247444 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 94 °C Intake air temperature: 34 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.796 V Dynamic environmental data: 209627117D0013E3B8135A02135B001355E313561A
Also, notice that the code was set when the engine was warm and not running.
P.S. Ross-tech website says the following:
When found in the Audi A6 (4F) and Audi Q7 (4L) models with 3.0L supercharged gas engines such as CCAA, CJWE, CJWC and CJWB this DTC points to a problem with Supercharger Control Valve (J808). It is NOT an IMRC system DTC. :
- Check wiring to/from J808.
- Verify J808 is not oil soaked or dirty.
- See Basic Settings and Measuring Block group 168.
For UDS ECM, Basic Settings IDE02226 - Adaptation of regulating flap for compressor
