There's a lot of outdated information posted throughout this thread as it was started a few years ago. I've made a lot of changes since the beginning, but I'll try to keep the main post up to date with the latest information.
Engine work
- Platinum rods and pistons from Italian RP with a slightly lower compression (10.3 CR), including ARP L19 rod bolts
- Main studs and head studs from Pro Series Fasteners
- Ported and decked cylinder heads with stronger beehive springs and fasteners from Supertech Performance
- Billet intake manifolds with fuel rails from Artek Motorsport
- Engine was built by Hybrid Tune in Diss, England
- Headwork was completed by CNC Heads UK
Turbo kit
- G35-1050 turbo kit was originally made by Walton Motorsport and further adapted by Hybrid Tune
- Full heatshielding on the manifolds and screamer pipe from Immico TLC
- Straightgate butterfly-valve wastefrom from Turbosmart, along with a Gen V Raceport BOV
- Boost control is performed with a Cortex EBC from SIRHC Labs
Fueling
- Upgraded HPFP that flows 97% over stock from RACE Poland - bored out HPFP that flows significantly more than all other options on the market
- OEM RS4 / RS5 DI injectors
- 6x ID1050-XDS port injectors from Injector Dynamics
- Ti E5LM LPFP from Artek Motorsport
- Port injection is driven by the Motiv Reflex from Motiv Motorsport
- Methanol injection driven by a TorqByte CM5-LTS from Torqbyte
Cooling
- Treadstone TR1245 intercooler from Treadstone Performance
- Oil cooler adapter plate from Four Season Tuning which replaces the OEM heat exchanger for an external radiator
- Large oil radiator mounted above the intercooler from Setrab
- 95c oil thermostat to replace the 115c OEM thermostat, generic VAG product
Transmission
- Stage 2 billet transmission build from Kotte Performance
- Higher stall lightweight race converter from Pure Drivetrain Solutions
Miscellaneous
- Full charge pipes from turbo outlet to intake manifolds fabricated by Hybrid Tune
- Larger throttle body from the 2.7TT with the above charge pipes enlarged to fit
- Billet PCV plate from Artek Motorsport with a custom catch can setup [catch can from AliExpress]
