All control modules with component protection aspects will turn on and be able to communicate. The CP exhibit for the MMI 3G era J794:
The information electronics control unit -1- J794 has a component protection feature. When the component protection feature is active, all audio outputs entertainment sources are muted. A message text is displayed on the MMI display when the system starts. The audio outputs for telephone and navigation announcements remain active.
If the J794 is shutting down, it could be the J794 or it could be the MOST bus. Just plug a male bypass loop onto the back of the J794 (the the J794 out loops right back into its in) and see if it runs without any of the car's MOST bus cabling or slave devices (radio R, and if installed, sound amp J525). (not tried it before, just seems the obvious thing to isolate external bus components; you could put female bypass loops on the loop plugs at the radio and J525, but that keeps any in-car optical cable issues in play).
It's not going to be an 8T... unit for B8.5 MMI 3G+. 8T... J794 are for MMI 3G in B8.0. For MMI 3G+ in the B8.5 for USA (PR-8DY), it'll be 8R1 035 664 for the version without the sim card slot and 8R1 035 746 for the version with the sim card slot. The revision letter in this specific case directly relates to when the unit was installed. Later revisions will be newer software, maybe any hardware updates. But a C or a F, you're going to apply the latest MMI firmware and navigation updates to either. C was used Nov '12 through May '13 (so later MY13 builds). F was used late May '14 through Oct '14 (so earlier MY15 builds).
