Results 1 to 17 of 17
    Junior Member Two Rings
    Nov 10 2021
    Milton GA
    Sound up - video - resonator and center muffler deleted
    Jul 24 2019
    Northeast
    Nice! Thanks for posting. The two smaller resonators seem like a no-brainer however, I'm not sure about the larger as it appears to also serve to mix or equalize both banks together(similar to an x-pipe)which is designed to promote a slight power increase.
    Quote Originally Posted by extrabolts View Post
    Nov 10 2021
    Milton GA
    Yeah, I saw some stuff about that, but honestly with a car that weighs this much and makes 700+ chipped, I don't think a few horsepower up or down really matters. From what I was able to find online, the most aggressive sound would come from straight pipes rather than X or H, so I went with it and am glad I did. The rear muffler also has a crossover
    Jun 19 2021
    Lots of dirt bikes
    Cape Cod
    Excellent video. Sounds great.
    Mar 31 2013
    2022 RS6 Avant, 2012 Porsche Turbo S, 1950 Jaguar XK120 Roadster, 2023 Expedition Max Stealth
    Western Slope of CO mountains
    Thanks for the video. Is this exactly what the red star res delete accomplishes? or does it only get rid of the center muffler?
    Dec 20 2020
    Arlington, VA
    Quote Originally Posted by dent2003 View Post
    Gets rid of the two front resonators and leaves the center one in place.
    Mar 31 2013
    Gotcha. Thanks very much. Then there are different Milltek systems - it seems one connects after the down pipes and eliminates the front resonators and the center muffler while providing new mufflers, and one that doesn't eliminate the front resonators and connects after the front resonators... Weird how many options there are.... They shouldn't have put in the resonators or center muffler in the first place!!
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Sounds great! You may wanna have an X or H pipe put in place of the straight pipes where the suitcase muffler was. It was an issue on the C7 when straight piping that section you wanted to have air pass through exhaust when the car goes into 4 cylinder mode.
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Nov 10 2021
    Milton GA
    Quote Originally Posted by Djpeaksd View Post
    Someone pointed this out on YouTube also. I did some research and do not think this is an issue for the c8. On my rs6, I have dual mufflers, one on each side, and the mufflers crossover connect to each other in the rear. The exhaust pipe from each side dumps into each muffler, and each muffler has a valved exit and a nonvalved exit. So exhaust can always get out of both pipes. It sounds like on the older model, for some reason the valve on one side was upstream of the muffler. This would mean that if you did not have crossover somewhere in the system, one side would be getting blocked off when in comfort mode and the valve was closed. But with the c8 rs6, from everything I can tell there is a straight line path out of the exhaust at all times on both sides even without a crossover.
    I'll definitely update if we notice any issues. So far we have put a couple hundred miles on the car and everything seems fine.
    Let me know if you know something different though? Getting an x-pipe put in isn't a big deal, but I do really like the sound now
    Feb 01 2016
    Encinitas, CA
    You know, you may be right on that! I believe on the C7 they did have a valve, further upstream on one side of the exhaust creating an issue when the car did go into 4 cylinder mode.
    Veteran Member Four Rings Treeskier's Avatar
    Feb 06 2017
    RS6; SQ5; Q7; S2k; ROW D90
    Philly
    i sourced an extra OEM exhaust because i didn't want to cut up my only one just in case i didn't like it ...planning to have this same mod done to mine over the next couple weeks. love the sound; great video.
    Dec 18 2011
    Ct
    This is a nice cost effective mod!
    Why go with the red star resonator delete which is $1200 plus install?
    Mar 31 2013
    Quote Originally Posted by Rcalcaide View Post
    Only reason would be easy to revert to stock...
    Jan 06 2022
    Florida
    Thanks for this video. I watched it countless times trying to decide whether to do this mod. I went ahead and bit the bullet at the same place the OP went to. Because I didn't want it too loud, I initially tried just removing the front two resonators. But that didn't make much of a difference, so then I went ahead and deleted the center muffler like everyone else. THAT made a big difference! But it's still not too loud in comfort mode, which I like. You can tell it's a V8, but it's not obnoxious. Then when you put it in RS mode...VROOM. Love it.
    Jul 07 2016
    Chicago, Illinois
    Quote Originally Posted by Tengorazon View Post
    How have you been liking it? No regrets? Any drone at speeds? Heavily debating this mod
    Aug 21 2023
    Hamilton, Ontario
    Quote Originally Posted by tymz View Post
    I had this done a few weeks ago. Sounds like it should have sounded from the factory to begin with. It has a nice growl to the exhaust in RS mode
    and sounds stock in comfort mode. No drone just better sounding exhaust.
    Feb 12 2020
    UT
    Great video and solid return on investment. Thank you, extrabolts!
