Results 1 to 10 of 10
    Junior Member One Ring
    Jun 22 2019
    CA
    Gains on bigger throttle body?
    Hello all. My car is dual pulley and tuned with 034. Considering getting their 85mm tb. Will i see any gains WITHOUT a ported blower? Wouldn't mind shelling out the money if i get some more throttle response and pick up minor hp.
    Mar 31 2008
    eS-4
    CAL*SO
    Port first! Sent you a pm
    Jul 31 2016
    PA
    Quote Originally Posted by Creepynoodle View Post
    What's your mod list right now?
    You wouldn't see as much benefit, but depending on how heavily modded you are there would still potentially be some.
    034 has had their TBs backordered forever though from what I gather.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    Sep 17 2005
    Fremont, California
    We measured about a +7WHP gain on E40 Stage 2+ with our SüperDüper Throttle Body Kit. As stated above, gains are mostly seen when paired with a ported supercharger as it will better take advantage of the increased airflow. A lot of the power gained with a Throttle Body is going to be up top in the rev-range.
    Should you get the SüperDüper Throttle Body before a ported blower? Definitely, so you can utilize the extra material we've left on the noodle allowing you to port-match it to the supercharger!
    If you already have our S34 Intake (Previously named X34), then the kit you would need is currently in stock! (034-108-1902)
    -Sean@034
    Established Member Two Rings TheGreatDecay's Avatar
    Feb 03 2017
    B8.5 S4, E30 325i m52 turbo, MK2 Jetta Coupe, MK1 TDi swap Caddy
    Winchester, VA
    Hopefully you do already have their intake - I’ve been waiting 4 months for it to ship along with their TB bundle.
    Jun 22 2019
    CA
    Quote Originally Posted by TheGreatDecay View Post
    I have an IE intake, will the tb only work with their intake?
    Jun 22 2019
    CA
    Quote Originally Posted by djn876 View Post
    Dsg tune, hx, divorced cooling loop, expansion coolant reservoir, ie intake, 187/57.
    Looking to go faster without E85 blends.
    Mainly up top.
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    Out of the box with no modifications, yes it only supports their kit.
    You can probably make it work with just about any existing intake with some level of modification
    2007 Porsche Cayman | 5MT
    Registered User Two Rings
    Sep 01 2021
    Branford / CT
    Hey, We have in stock 034MOTORSPORT SÜPERDÜPER CHARGER 84MM THROTTLE BODY SYSTEM.
    We offer free and same-day shipping.
    Feel free to Dm me with any questions you have.
    Here is the link to the 034MOTORSPORT SÜPERDÜPER CHARGER 84MM THROTTLE BODY SYSTEM
    https://xlr8performance.com/i-77681-...LR8&utm_id=034
