Crank no start… checked voltage at the pump with ignition on, tried it wile trying to start it as well. No voltage. People say it’s the 219 relay under the hood. I check that relay tested it properly it’s totally fine. I’m told there is also a fuse somewhere but of course I can’t find much online. I check where other people show theirs is and I got nothing there.
Sometimes it will crank and start idling and runs for awile I drive it around the block all good, I do full pulls drive it real hard no problems then It bogs out and shuts off. Won’t start and I no longer hear fuel pump priming.
Things I have replaced.
-Fuel filter
-219 relay
-All 4 could
-A4 spark plugs
Also I’m not sure where I should be posting this. I am new member here and they won’t let me post where ever I want. Still learning this forum stuff…
