2016 S4, so 3.0T CTUB.
P2004 Intake Manifold Runner Control Stuck Open, Bank 1, Signal voltage > 2.5 V
P2005 Intake Manifold Runner Control Stuck Open, Bank 2, Signal voltage > 2.5 V
P2006 Intake Manifold Runner Control Stuck Closed, Bank 1, Signal voltage < 2.9 V
P2007 Intake Manifold Runner Control Stuck Closed, Bank 2, Signal voltage > 2.9 V
P2008 Intake Manifold Runner Control Circuit/Open, Signal voltage 2.9 to 3.2 V
P2009 Intake Manifold Runner Control Circuit Low, Signal voltage < 1.95 to 2.2 V
P2010 Intake Manifold Runner Control Circuit High, Signal current 1.2 A
P2014 Intake Manifold Runner Position Sensor/Switch Circuit Low, Bank 1, Signal voltage, < 0.2 V
P2017 Intake Manifold Runner Position Sensor/Switch Circuit High, Bank 1, Signal voltage, > 4.8 V
P2019 Intake Manifold Runner Position Sensor/Switch Circuit Low, Bank 2, Signal voltage, < 0.2 V
P2022 Intake Manifold Runner Position Sensor/Switch Circuit High, Bank 2, Signal voltage, > 4.8 V
So there's:
G336 intake manifold runner position sensor bank 1: 5v on white on 1, signal out on yellow/red on 2, ground on brown/green on 3.
G512 intake manifold runner position sensor bank 2: 5v on white on 1, signal out on violet on 2, ground on brown/green on 3.
N316 intake manifold runner control valve: fused 12v on yellow/red on 2, ECM controlled ground on blue/white on 1.
It seems the issue would be with the N316, not the G336, based on the text. Could be a failure in the unit or the wiring from the unit to the ECM (T60/36).
