Its a 2011 CAEB engine, with 100k miles pistons were never replaced. They are the old style with the 21mm wrist pin.
The following day I checked for codes, car was ready for an inspection. It had no codes.
Then I thought to remove the spark plugs and take a look inside the cylinders with a borescope.
The top of one piston (Cylinder #2 is very clean) and piston #1 is cleaner than the other 2.
I wondered if I have a leaky fuel injector, I hooked VCDS, the fuel pressure does not rise after i shut off the car. In about 3 minutes it dropped from 4010 kPa to 3620 kPa.
In 500 miles the engine used 1/2 a quart of oil.
https://photos.app.goo.gl/sgfBQ4B8Y6YbKR8F8
I am not sure how to check for leaky injectors. Any help would be appreciated.
Thank you
