Hello,
So I've bought a 2015 Q5 3.0 with the ZF8 transmission.
The Car has 175000 km on it.
I have just changed the oil of the transmission, 2 differentials and transfer case. I've Used original audi oil for the difs and the transfer case and Lifeguard ZF8 fluid for the gearbox. Everything is with the correct specifications. ZF8 Service kit was used!
Now the problem is that when I am driving the car in D and it is in 2nd gear, and I floor it, the gearbox starts jerking and doesn't know on which gear to shift. It eventually shifts to 3rd. But the jerkiness can lead to a P0780 code which is: Shift Malfunction.
Anyone faced this problem after transmission fluid change ? Will Gearbox adaptation reset from VCDS fix anything ? I've read alot of post suggesting that this is one way to fix any abnormal gear shifting after transmission fluid change.
I will try the Trottle adaptation reset tomorrow.
