Results 1 to 20 of 20
    Junior Member One Ring
    Nov 14 2018
    Boalsburg, PA
    B6 1.8T Cracked Cylinder Head Replacement Options
    Ouch:
    Been chasing a cylinder #2 cold misfire for awhile that started this summer. Checked for signs of coolant in cylinder head and found none so went down the rabbit hole of checking injector, coil pack, wiring, 30397 chipset with no success. Re-checked #2 for coolant again this week with cold weather and found some, so it is looking like I may be one of the many that has a cracked AMB head.
    Car is a 122,000 mile A4 Avant USP that is in great shape and runs really well (K04-15, Milltek HFC, Milltek resonated exhaust, AWE intercooler and Motoza tune). Totally ignorant of potential options for head replacement and hoping for some help...
    Thanks,
    Jim Casselberry
    Aug 02 2021
    Southern Miss
    Pretty much any 1.8t head that came on a VW will work. But then there’s the ‘may as well while you’re there’ items of timing belt and water pump. I went with a manual tensioner while I was there, too.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I would recommend getting a rebuilt AWM that was cast in Germany.
    I also recommend using the newer Litens timing belt tensioner. Clicky click®
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    I would also recommend the newer Littens tensioner. Crankcase vent tube since the head is off. Any of the newer small port heads will work. If your cam chain tensioner is a known good one it you might want to swap it over. Almost any used head will be a candidate for new exhaust guides.
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    I also installed my first Litens tensioner this past summer. So simple and basic makes you wonder why they didnt think of this in the first place.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Established Member Two Rings Ben.Nesheim's Avatar
    Jun 26 2020
    wisconsin
    i would have to say second hand head is your best bet and agree with the litens kit recommendation.
    B6 A4 1.8t 6spd manual
    MKVI Jetta S 6spd auto lol
    Sep 10 2021
    Pennsylvania
    I just did this. I went to Autozone.com and got a remanufactured head from them. When I did it, it was 20% off and they did free shipping. Someone here pointed me that way (thanks, by the way!). The engine code was ground off the top, but it wasn't an AMB head like I had (though it fit an AMB car perfectly). I know it wasn't AMB because it has "GERMANY" cast into the side (and it's not cracked into oblivion). It was a couple hundred bucks after the core charge return--I think $500-600? Way cheaper than having one machined. Interestingly, it was missing a bunch of studs, so buy new ones for yourself for the exhaust manifold, valve cover, timing belt idler, etc. so you don't have to do the job half-way like I did by reusing studs that you shouldn't reuse. It already survived 2,000 miles of commuting to work and a track day at Summit Point Motorsports Park.
    I don't know if it'll help you, but I'm doing a two-part YouTube series on exactly this job. The second part, which I am editing as I type this, should be up tonight or tomorrow. When I filmed the first part, I suspected that the head gasket was just blown, but I found the cracks when I pulled the head off. It's not meant to be a how-to guide, just hanging out with me in the garage and as often as I can, at the track. I run into a bunch of snags as I go along, so you can share in my frustration. I hope maybe you find it helpful. https://youtu.be/QUFDSOy1Q08
    A4SoftWalker, what's a Litens tensioner? Is it reusable? I had to throw mine away after using it for 1,000 miles because of this head issue. That was an expensive mistake.
    Mar 28 2015
    Quote Originally Posted by Mike Tries View Post
    FYI, my 2003 AMD had a German cast head.
    Littens tensioner: https://www.blauparts.com/audi-a4-ti...-amb-base.html The tensioner is built into the idler pully.
    May 13 2008
    NoCal - EBay
    Quote Originally Posted by Kevin C View Post
    Thanks Kevin for the link with included description from BlauParts. This is where I got my kit from. The Litens technology uses an actual coiled spring instead of a hydraulic tensioner to maintain timing belt tension.
    It is very easy to reuse I was able to reset mine several times during the installation process. If anything it was nothing more than me being nervous I set it correctly and torqued it exactly.
    If it was a traditional tensioner it would have been a lonnnng ordeal compressing the hydraulic pistion and resetting the tension. My last hydraulic timing belt tensioner was found to be leaking and the belt slack with tiny belt powder particles collecting in clusters while doing my timing chain tensioner on the back of the cylinder head.
    That was scary. I had to rush order the BlauParts kit and prepare myself to do a timing belt job I thought was maybe due in the next 3 years at the soonest.
    Anyways long story short Mike Tries: Litens = Life back in terms of timing belt wrenching headaches...
    'SOFTWALKER MODS
    Avant>Sedan! Click
    Aug 02 2021
    Southern Miss
    I used a febi branded tensioner, reused the bolt/nut, and reused the hydro tensioner for the idler pulley. A new belt snd metal water pump. Based off a write up I found on Vortex. Easy peasy. Should’ve done this years ago.
    Mar 28 2015
    Quote Originally Posted by Brake Weight View Post
    Litens was the original designer of the sprocket tensioner and the company that was approved by VAG. The design has been out at least 16 years and the patent may have expired. In the past if you got that type of tensioner it was a reboxed Litens part, that still may be true. They have a crazy number of patents for tensioning belts.
    http://www.litensaftermarket.com/timingbelt#sub12
    Aug 02 2021
    Southern Miss
    Not knocking this litens kit as this is something where quality is paramount. I believe I searched for a VW mk3 tensioner to source what I ended up buying. Which would be late 80s through 90s. I believe the latter mk3s had a hydro style so there may have been some trademark/patent squabble…or I may be just confused again.
    Veteran Member Four Rings Gin+'s Avatar
    Apr 16 2015
    CNY Syracuse
    I believe I just read the review you left for it on autozone's website
    They're not scared of you. They're scared of what you represent to 'em.
    Mar 28 2015
    As a reference, I bought a used head for at a pick and pull $70, new guides, cut valves, seats and resurface was about $350. I put the head together myself and did the porting.
    May 13 2008
    NoCal - EBay
    I believe the VW Mk4 from 1997-2006 had the 1.8T 20v motor similar to our cars.
    'SOFTWALKER MODS
    Avant>Sedan! Click
    Aug 02 2021
    Southern Miss
    Quote Originally Posted by A4SoftWalker View Post
    Yes. I have one of the 1.8t 6spd Jetta GLIs that got totaled recently. I used the claim money to get my B6 Avant. Already pulled the AWP head to replace the AMB. Robbed the coolant sensor two days ago, too. Plan on either refurbing that block or get a new block and swapping the forged internals and Wiseco pistons over for the B6. Looking to swap the return style fuel rail as well. Wish the BT tuned ECU would swap but I’ve read that it won’t work with the dash cluster.
    Sep 10 2021
    Pennsylvania
    Quote Originally Posted by Gin+ View Post
    Oh, haha, did you find that helpful?
    Sep 10 2021
    Pennsylvania
    That sounds like a good way to do it too. A good deal, plus, you don't have to return the old one for a core charge.
    Mar 28 2015
    I had more time than money and or common sense. That and it was a spare motor that I was building as a side project.
    Apr 16 2015
    CNY Syracuse
    Fortunately I'm not in need at this time but I'm sure someone will definitely find it helpful.
