Audi A4 B7 - P0118 G65 Sensor - SOLVED
As Summer heats up having my son’s AC not working is a big deal. I purchased the car used and it has never worked, throwing a P0118 error. I’m a fairly technical guy (former NASA engineer) but not an auto mechanic. I thought I’d walk everyone through how I solved this very complex puzzle so that someone can save themselves the 100 hours I’ve spent on it. My A4 was used with extensive work (of unknown quality). Given the number of broken connectors I don't think an Audi dealer was doing all of the repairs.
I have lots of tools including signal testers and wave form generators. Also have VCDS (highly recommended $200) and the Bentley manual. Some of the pages are in links above for this issue.
Key Lessons
1) DO NOT buy parts until you diagnose
2) Audi control systems are complex. The computer controls the compressor function, if it does not obtain a proper signal it will not turn on the compressor.
3) Purchase a Bentley manual
4) Start with the
Ross Tech HVAC season Diagnosis Post before you do anything
5) Go ahead and remove the bumper. It takes 15-20 min.. Its not really that bad.
6) Buy a Vehicle super probe to read resistance, voltage and waveform. (
mine is here $70 on Amazon)
7) Drive to your local parts store and read the refrigerant pressures on both high and low side.
Troubleshooting and diagnosis
A. P0118 preventing AC Compressor from engaging. Link to Ross Tech overview of P0118 is above with detail below. 00819 - High Pressure Sensor (G65): Open or Short to Ground
Possible Causes
1) Wiring/Connectors from/to High Pressure Sensor (G65) faulty
2) High Pressure Sensor (G65) faulty
Possible Solutions
1) Check Wiring/Connectors from/to High Pressure Sensor (G65)
2) Check High Pressure Sensor (G65)
B.
VagCom reading of HVAC Log blocks 1 and 2 show 0% duty cycle and 33bar (100%) high pressure signal with shut off codes 1,4 and 3. These codes c
an be interpreted here.
C. Removing the front bumper and disconnecting the pressure sensor I measure voltage of 3 pins. The PIN diagram is show in the
Bentley manual above. For my car, Pin1 is brown wire (ground), Pin 2 is Signal Wire (Brown/Blue) and Pin 3 is power on A38 wiring harness. Using a multimeter I check the connector for proper voltage. Pin 1 is ground so checking PIN 1 Voltage to Battery+ shows battery voltage. Pin 2 is Signal and shows 9.9V, PIN 3 is power and shows battery voltage. Additionally I check Pin2 continuity to both the Station A Pillar Connector14 (T10d) in wiring diagram above. The A pillar connector is located near drivers left foot. Just take off the fuse cover and the molding should come straight out. Continuity (resistance) was confirmed.
D. Next is to check the
signal wave form for the current G65 pressure switch using my Vehicle probe. I did not want to take apart the connector to the G65 switch, so I went back to the connected 14 connecter (T10/d) in the drivers footwell to touch the vehicle probe to the T10/d connector while the probe was in wave form reading. With the car running and air conditioning turned on the reading is shown below. It was pegged at 100% and 10.4 volts .
Picture of probe readings
E. Given that I had established that the G65 connector was fine and there were no wiring issues. I thought that this signal indicated I needed a new G65 sensors. After ordering and installing. The same problem persisted. I then ran across this
Audi TSB for G65 (for 2009 A4 and mine is 2006.. But G65 sensor is same). It this TSB they provide
overview of wave form and process to diagnose.
F. The waveform above is square wave 50Hz, 12 V. From #4 above, PIN 2 (signal wire) unplugged from the G65 sensor was reading 9.9 V (car on).This
great youtube video on checking signal. Gave me a great idea. Why not artificially give the ECU the proper signal just to confirm everything else works.
G. I purchased a
$30 signal generator and did a quick calibration for 50Hz Square wave and 10V. Then injected the generated signal into Pin 2 while grounding to Pin 1.
Everything worked.. Air conditioning started. While running I recharged the air conditioning (at added quite a bit).
H. Then I turned car off, reconnected the connector to G65, and ran A/C again. Hooking up VCDS showed a
fully operational G65 with normal readings. Somehow the very low pressure in the AC (now recharchaged) or a the artificial 50hz signal allowed everything to work again. It looked like the previous owner struggled with this problem. I see a new A/C pump and G65 also looked new. My guess is that some how the ECU needed a reset. Note that prior to this fix, I did measure A/C pressure on both high/low side. They were low but within limits and adding refrigerant to low side did not resolve the G65 P0118.
This was the hardest troubleshooting project I’ve ever had. My Audi dealer wanted $2k from me and said I needed a new master climate control panel. I spent about $50.. It made no sense at all. Thought I would share.
Great Audizine and VCDS links you should review on this topic
https://forums.ross-tech.com/index.php?threads/633/
http://wiki.ross-tech.com/wiki/index.php/00819
https://forums.ross-tech.com/index.php?threads/10880/
https://forums.ross-tech.com/index.php?threads/12600/
https://www.audizine.com/forum/showt...er-replacement
