Results 1 to 12 of 12
    Junior Member Two Rings
    Feb 23 2020
    Chi Town
    adaptive headlights?
    I'm trying to determine if the 8v has adaptive headlights (swivel when turning the steering wheel). I don't notice this myself when I am in my car driving at night and searching this forum was inconclusive. Can anyone confirm? I have a 2017 S3 Premium with dynamic and technology package.
    Thanks.
    Nov 23 2018
    New Jersey
    Quote Originally Posted by fizmixa View Post
    Thanks.
    I own a 2017 S3 as well. Yes they should swivel. Based off steering wheel input you will see the light shift from side to side. I believe they actually use the "all-weather lights" to emulate this effect. I know this because when you turn the switch on and off you will see for a split second the shifted light turn on and then off.
    Sent from my LM-V600 using Tapatalk
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Really? cool. Prolly only if you opted for the matrix LED headlights.... I know my older one doesn't have those.
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Veteran Member Three Rings XMetal's Avatar
    Nov 02 2017
    CA
    Quote Originally Posted by Spinnetti View Post
    It's just using the "fog" light...just like Nissan always been doing.
    2018 Audi S3 Premium Plus
    Navarra Blue Metallic/Magma Red - Technology, Dynamic, S Sport, Black Optic, Resonator Delete, Unitronic Turbo Inlet, EQT Stage1 ECU/TCU
    Feb 23 2020
    Chi Town
    Quote Originally Posted by Davethaboss View Post
    I believe you are talking about the "cornering" light that turns on when you make a turn. I am asking about the actual LED headlight swiveling as you turn your steering wheel. I know Golf R's have this feature but from what I can tell now, doesn't look like my S3 has it.
    Nov 02 2017
    CA
    S3 LED headlights don't swivel left/right, only up and down.
    Feb 23 2020
    Chi Town
    Quote Originally Posted by XMetal View Post
    Thanks. That is the conclusion I also came to.
    Nov 23 2018
    New Jersey
    The S3 lights use all weather lights as quasi cornering lights.
    The S3 headlights will actually dip just slightly at high speeds to prevent the car from blinding other drivers. You can also observe this behavior on car start up. When I turn the car on the headlights in my car dip and then go up, and then re-level. So there is a function that allows it to tilt up or down.
    There is none that allow it to pan left or right though. I am curious to know if there is manual adjustment for that now. For example, if you get into an accident and want to shift the headlight housing horizontally because it got shifted during the accident. I am going to take a look later.
    Dec 10 2004
    R8_LS400
    Dallas, TX
    The up and down at startup is just a leveling test and vertical movement is only used to adjust for load in the car as I understand it. If you want cornering lights, look elsewhere, like the Citroen DS (came out in 1955) that turned the lights with the steering wheel so you lit up where you were going - long overdue for all cars to have this! :)
    Nov 27 2020
    Florida
    Vcds coding below adds the artificial cornering light for those that don't have
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Quote Originally Posted by noseyp View Post
    But still requires the adaptive headlight option for it to work at all ya?
    Nov 27 2020
    Florida
    I can't confirm as I haven't coded this mod myself yet but all the other vcds changes I made were from the same source and they work (link with everything below). The description (which may not be legible in the image) says "the coding will allow you to activate the static cornering light function utilizing the audi standard fog lights."
    https://redirect.viglink.com/?format...3Dfile%252cpdf
