I had a small leak develop and thought it was the thermostat or crossover pipe because it was coming from there. Thermostat was fine and functional but still replaced, water pump was not leaking but still replaced. Crossover coolant pipe connection to the thermostat was deteriorated and had coolant pooling so I guessed that was where the leak was coming from. DIY replaced pipe and all o-rings. There was still coolant pooled up and streaks over the front of the engine and I cleaned up what I could, but there was still coolant dripping from the passenger side of the oil pan with the engine on. The longer I had the engine turned on the faster the stream. I bled the whole system and it took about 1.5 gals to max then took it out for a test drive and steam kept coming from the passenger side. Temps stayed at 199-213C. When I got home and checked coolant level, it was 3 inches below min and there was some coolant on the passenger side of the metal skid plate. I can't find where it could be coming from. I checked all the bolts are torqued to spec and its does not look like its coming from the crossover pipe, water pump, or thermostat. Supercharger IC cores are also intact. Radiator and intercooler are dry; it seems to be coming from the passenger front of the engine. Any ideas?
EDIT: Vacuum tested system before filling coolant. Held with a small gradual loss for 10 mins at 1 bar. Supercharger valley was dry so I'm guessing its not the PCV.
