I think it helps wake it up.
BTW here are my instructions just in case someone's is MIA. You still need a valid user name / password.
Please read these instructions in their entirety before attempting to flash the transmission or contacting support.
First, you will need to install this software and let it update to the latest version if necessary.
https://adt-software-updates.s3.amaz...ler+Client.exe
Plug in the cable, start the SRT Flash Tool, and log in with the following credentials:
User Name:
[email protected]
Password: example
(user name and password used as example only)
Flashing Steps:
1. Connect a battery charger to the vehicle. Open the hood and open the driver door. Do not close either the hood or driver door during the entire process.
2. From the main menu, select "PROGRAM TRANSMISSION"
3. Fill out your customer information and click "CONFIRM"
4. Select the binary you would like to flash and click "CONFIRM". See notes below.
5. Click "PROGRAM" and follow all on screen instructions. Before flashing, verify the battery has a full charge, and if there is any doubt, use a battery charger. Turn off all accessories such as headlights, air conditioning/heater/fan, etc... The transmission flash will take between 30 seconds and 5 minutes.
6. Follow the on screen prompts until the flash is complete. Upon completion you should see a message that says "Controller successfully programmed"
Additional Notes:
1. Some software versions must be updated to a compatible version before the tune can be applied. In this case, You will only see one option, "Update to S####" Please select this and flash it first, and then close the software and restart the process to be able to flash the performance binaries. This is only performed the first time you flash.
2. In the binary selection phase, you will select the desired Shift RPM in the first drop-down box, and the desired Launch RPM in the second drop down box.
Suggested shift RPM:
6600 is factory
6200 RPM or 6600 RPM shift points for stock turbos, Plus 4, or TS1
7000 RPM for Plus 4, TS1, or larger (requires custom ECU tuning to suit)
7400 RPM or 7800 RPM larger than Plus 4 or TS1 turbos only (requires custom ECU tuning to suit)
Launch RPM selection:
Start low and keep increasing until desired wheel spin and launch speeds/times are achieved
3. The following clutch adaptations must be performed after flashing using a VCDS cable or another suitable scan tool.
Main Pressure Valve Calibration
Clutch Valve Calibration
Clutch Engagement Point Adaptation
Distance Sensor Calibration
4. It is possible your software version has not yet been covered. If during the process you receive the message "No program found for controller" Please reply to this email and we will add it for you.
