Hey Guys,
After retrofitting an RNS-E into my B5 S4, I got this error, and a washer fluid warning light.
I tried recoding my cluster on channel 60, but it's already 0 (it's correct for me). What can be the possible solutions for it? Which pins are the can for the ECU? Maybe there is a problem. Maybe it will solve the washer fluid problem as well.
Also if not, how can I short the washer fluid in the cluster? I see pin 15 is the level sensor, but leading it to the ground is not the solution I think.
