So i finally got around to doing my pads (EBC yellow Stuff) and rotors (Mtec). I drove about 15 miles and realised, i've put the bloody rotors on the wrong way. They are Mtec (U.K company) grooved and dimpled rotors and according to their website https://www.mtecbrakes.com/brake_dis...ing_bedding_in they are directional, so the grooves and dimples are going the wrong direction to what is apparently right. Interestingly the ones on before, drilled as standard, they were not directional meaning the drilled holes on one faced one way and the other the opposite way (when fitted).
Does anyone know if this really matters? I'm dreading having to take everything apart again and swap them over. I looked at the vents between either side of the rotor, thinking they might be directional and thus cooling would be affected however from what i can tell they are straight and don't go a certain direction.
Also perhaps someone could help me out with another thing. When braking it feels a little bit juddery / grindy, is this normal? Only done light braking so far. When i installed them i spun the wheel and there was scraping followed by no noise followed by scraping, suggesting the rotors were not on straight. After i tighten and torqued the wheel bolts the scraping was gone when i spun the wheel.
Another thing i just remembered, there is a slight chattering / ticking / clicking type sound when i go above 30mph. Kind of sounds like a stone stuck in a tyre but not as fast. Anyone know what it could possibly be?
Many thanks as always :)
