Results 1 to 11 of 11
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    Q5 3.0 TDI DPF delete cost
    hey guys how much have you spent between tuning and piping for DPF CAT deletes?
    Whos the go to any others besides rawtek darkside and buzken? Is this something a local shop can fab up or are the flanges a problem to match
    May 20 2010
    Hardware from Darkside cost me $360 shipped from the UK (included the gaskets, etc). The tuning was $898 from Malone for Stage 2 and deletes, and another $50 from my shop to do it (already a Malone rep).
    A custom delete would probably more based on the bends, flanges, and bungs to weld. A competent shop would certainly be able to do this, and any other exhaust pieces you'd like.
    I cannot say there are other "go to" deletes other than the ones mentioned. I like the Darkside, as it felt really good in the hand (very well made; welds were impeccable, high quality 316 stainless).
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Nov 10 2010
    Stoney Creek
    thanks for responding, was that 360USD or UK pounds?
    May 20 2010
    Good catch. That was 360 pounds sterling. $464 USD shipped at the time.
    Nov 11 2018
    WA, Aus
    Have been recommended to gut the DPF as another alternative. Shop mentioned they open up the DPF and remove the insides and weld it up again, bit more stealth. Might be another option?
    Nov 10 2010
    Stoney Creek
    Thats def another option but with the cost of the dpf i think its best to keep it if you ever need to go back to stock
    May 20 2010
    ^^This, esp with the dieselgate warranty
    Nov 11 2018
    WA, Aus
    Quote Originally Posted by kt883 View Post
    Ya for sure. Unless you are chasing big power and the DPF still works, just keep it. I'll be getting my tune next month and was advised exactly that. I don't intend on swapping turbos or anything in the future (maybe an intercooler?) so won't really need it.
    Cheers
    Nov 10 2010
    Stoney Creek
    see I want the sounds (and the power bump) from DPF delete. Going from a 2008 TT 3.2...to a 2010 S5 V8 w straight pipe...to a straight piped 2013 S4...I'd like to have something that sounds good and turns heads
    May 20 2010
    Can't really say there is a sound from the DPF delete... at least nothing like changing the rest of the exhaust.
    Account Terminated One Ring
    Nov 25 2022
    william
    Buzken parts aren't always too cheap. But I'm willing to buy this as my DPF gets dirty. I need this gasket. I often drive downhill, straining the engine. And I sometimes have to tow trailers on the farm. Of course, I regularly clean the particulate filter. Once I forgot about it, and the car stalled. I called the DPF cleaning professionals from https://www.30minutedpfclean.com/pro...ning-services/. They cleaned the filter in 30-40 minutes. And I drove on. They came straight to my farm, so everything was fine. But it wouldn't be much fun if the engine stopped working somewhere in the forest belt or field.
