Results 1 to 2 of 2
    Mar 20 2019
    Sydney
    Help with Gearbox Malfunction - DTC: Shift Fork 4 Position Sensor / P2848 00 [096]
    Hey everyone,
    Last week as I was driving my B8.5 S5 I got a Gearbox malfunction message on the dashboard, it said reverse is not working and a TPMS (tire pressure Monitoring System) light lit up as well. When the lights came up I lost traction for a couple of seconds as the engine would be revving up but no power was transmitted to the wheels. Eventually, the car managed to shift to a gear and I was able to move forward. I stopped immediately, I couldn't reverse the car so I turned off the car. After 5 min I turned it on and all the lights were gone, reverse gear worked and I was able to drive without issue. I thought it was just a glitch.
    Today the exact same issue appeared. As I was accelerating I got a gearbox malfunction message, reverse unavailable and TPMS light on the dashboard. The car struggled to shift and skipped gears from D4 to D7, still I managed to pull over and turn off the engine.
    I got home and scanned the car with VCDS and I got the below codes.
    18056 - Shift Fork 4 Position Sensor
    P2848 00 [096] - Incorrect Neutral Position
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 40
    Mileage: 35073 km
    Date: 2021.09.10
    Time: 15:35:10
    Engine RPM: 2878 /min
    Transmission input speed: 2878 /min
    Transmission output speed: 528 /min
    Engine torque: 20 Nm
    ATF temperature: 100 °C
    Accelerator pedal position: 4.8 %
    Clutch status: Kupplung 1 kann Moment übertragen
    Unlearning counter according OBD: 40
    01315 - Transmission Control Module
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 29
    Mileage: 35073 km
    Time Indication: 0
    Date: 2021.09.10
    Time: 15:35:11
    Online I found the below possible causes for code P2848.
    Outdated Transmission Control Module (TCM) program (Reprogram TCM)
    Faulty Transmission Control Module (TCM)
    Faulty Transmission Assembly
    Can someone help me understand what's a TCM? Is it a known issue on B8.5 S5? Is it known to fail on those cars? Where is it located? Can I visually inspect it?
    Will I have to take it to Audi to fix it?
    Thanks in advance for any insights you may have. I never dealt with transmission however, I'm pretty hands-on so please let me know if there is anything I can do/check myself before taking it to Audi.
    Thanks
    Mar 20 2019
    Sydney
    Here's a pic of my dashboard when the issue occurred
