Results 1 to 9 of 9
    The perfect tire size for 21 x 10.5 wheels?
    Looking for some recommendations and pics for the perfect tire size to my liking. Currently running the stock 21” wheels on my 14’ RS7 with 275’s. I don’t want any tire stretch as I would like the same look as the stock wheel set up. My new wheels are Vossen HF5 21x10.5 et30.
    Veteran Member Three Rings choy188's Avatar
    Jun 02 2019
    2019 S5 Sportback, 2022 Polestar 2; Sold: 2012 A6 3.0T, 2006 A6 4.2
    Danville, CA
    It should be a 295/30r21
    Sent from my SM-N986U1 using Tapatalk
    2019 S5 Sportback Prestige | Navarra Blue Metallic | Black | Options: Sport Package, Dynamic Steering, Cold/Warm Weather Package, Black Optics, Direct TPMS Retrofit
    Sold: 2012 A6 Prestige | Oolong Gray Metallic | Titanium Gray | Options: Innovation Pack, Cold Weather Pack | Mods: Lane Assist Retrofit, Injen Intake, 034 Stage 1 ECU+TCU
    Sold: 2006 A6 4.2 | Atlas Gray Metallic | Platinum | Options: Technology Pack, Cold Weather Pack
    Quote Originally Posted by choy188 View Post
    Thanks! Wasn’t sure between that and 305s. I don’t want the stretch look nor the balloon look.
    Jun 02 2019
    Danville, CA
    Quote Originally Posted by eurodaddy View Post
    305 would be at the maximum for that width which is where you'd get the balloon look, if you want the squared off look it's always the size below the max for the wheel width
    Thanks again! The 295s it is.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    FWIW my opinion varies slightly.
    Audi tends to use 0.5" lower rim widths than "industry standard measuring rim width" to get their specific look.
    Examples:
    255 on a 8.5" instead of industry standard measuring rim width of 9" and your 275 on a 9" instead of a 9.5"
    That being said the standard measuring rim width for a 295 is the 10.5" so in my opinion it will not match the Audi look exactly and will be very very slightly stretched.
    It will still look good and is probably your only option since a 305/30 might be too big to fit the car and a 305/25 would have as staggeringly small sidewall.
    I know it is not exactly what you are looking at but the only comparison I have is my own.
    The top is 265/35/20 on 20x9
    The bottom is 255/35/20 on 20x9. (This is the Audi stock size tire for my car which uses a stock 8.5" wide wheel.)
    So you can see the 255 is very slightly stretched on a 9" even though that is the industry standard width and the 265 is more squared.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Quote Originally Posted by gk1 View Post
    Examples:
    Thanks for that! That is good to know!
    Junior Member One Ring
    Mar 02 2020
    England
    For 21x10.5 wheels, I would recommend going with a tire size of 285/30/21. This size will give you the same look as your stock setup and will fill out the wheel nicely. It's also a pretty common size for that wheel width, so you shouldn't have any issues finding a good set of tires. As for pics, I unfortunately don't have any on hand, but a quick Google search should bring up some great examples. When it comes to custom tires, I actually got mine from corwheels.com. They have a great selection and were super helpful in getting me the perfect set for my wheels.
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Different tire manufacturers will also have a sightly different profile, for the same size tire... if that matters to you. Michelin 295/30 has a different fitment than a Conti, or Firestone, Pirelli, etc. It's been discussed a few times and widebodyfx has shown some pics illustrating the differences. Comes into play if you lower the car
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
