Results 1 to 13 of 13
    Junior Member One Ring
    Mar 07 2020
    charleston, sc
    Looking at High Mileage A6
    Hello,
    I'm looking at purchasing a 2012 A6 3.0T car with 184k miles. How long does this engine typically last? Also, is there anything I should look out for in particular?
    I have a Q7 with the same engine but it's only at 84k miles.
    Established Member Two Rings SteveC's Avatar
    Nov 13 2020
    North Dakota
    I have a 2017 A6 with 60K+ so I am curious as well.I'd like to keep this car for a while if I can.
    2017 A6 3.0T Supercharged Premium Plus S Line
    Sport and Cold Weather Packages
    Audi logo puddle lights in my doors, spacers and caliper covers.
    Sep 16 2020
    West Michigan
    I have 165k on mine. It needs a few of the 'normal' maintenance things at this point. PCV, etc.
    It has been APR stage 2 since 150k and seen some pretty excessive speeds during those times.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Mar 07 2020
    charleston, sc
    Nice. The car I'm looking at has 184k miles but looks like it's been well kept. Is their anything I should be looking for in particular on the car?
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    I'd just pass unless it costs an insignificant amount of money to you and/or you don't mind doing/paying for some very involving/expensive stuff like timing chains and/or cats. At 184kmiles, it's a complete gamble how much life it has left in it. Buying a car with such high mileage is just a bad idea, never mind Audi's fabled reliability and ease of diy repairs. It is an A6, though, so chances are it had an easier life than a comparable S4 and has a trans which actually works. Bottom line - if it costs an insignificant amount of money to you then gamble, if not then pass.
    Sep 16 2020
    West Michigan
    I'd do a cold start and listen for rattle upon startup with the hood open.
    Get under the car and look for oil leaks, etc with the belly cover off.
    Check the control arm bushings for wear. (I had to do all front control arms on mine a year after purchase at around 135k miles)
    Hard to quantify oil consumption via PCV etc during a test drive. So it is a gamble there. But the PCV, waterpump, thermostat are hit and miss seemingly anyway.
    Ask for paperwork on intake valve carbon cleaning (typically done during PCV service) and Secondary Air Injection.
    Bring a GOOD scan tool?
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    12 X 12 is 144. That is the normal usage, so I would have to say this was a salesman that did a LOT of highway driving. I would think that's is better then a car with half that and a lot of crazy driving. Like mentioned I would have it looked at and get the maintenance records and don't forget the leak down test on compression.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    214K on my 2012 A7. Last summer (around 204,500 miles) I had to pull the motor for timing chains but otherwise she is running good. There is a guy on Audiworld that last I saw was over 345K miles. I think I have a rear shock going bad but I have to make time to get under it and check. My suspension is original so if its a bad shock I will replace both rear shocks and think about the fronts depending on price.
    I did my motor mounts when I did my chains as well. Previous owner had 2 of the wheel bearings replaced and then just normal maintenance stuff on the car.
    Mar 07 2020
    charleston, sc
    Thanks everyone for all the replies! It's been really helpful. I'll probably be bringing a vag-com
    Mar 11 2007
    Colorado Springs
    IMO, the 3.0t (SC) is as bullet-proof as the old 2.8 V6.
    If it's been serviced you're probably good to go, BTW I just gave my brother an A6 2.8 PES SC w/ 245k. Running like a top.
    It's all about the service records. If it got this far, you can assume it's been serviced, but do your homework.
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Nov 27 2018
    Valparaiso, IN
    Service records may or may not tell the story of the car. When I bought mine used I had the car fax report that said it went to the dealer about every 10,000 miles but said very little about what was done other than “recommended service performed” while other car faxes I have seen go in to greater detail. I was able to get a copy of the records from the dealer to see what they actually did. BUT, if it was ever taken to an indie shop that is typically not recorded much of any place. Also when I sell or trade mine in there should be nothing on an “official” report during my ownership since I perform my own work. I keep a list of what I have done but it’s certainly nothing official.
    Apr 23 2019
    CA
    Quote Originally Posted by A6sport View Post
    That 2.8 v6 has a timing belt in front instead of the chains in the back so 3.0t def can have more problems. I don’t think 3.0T is really that bulletproof, not as bad as 2.0T but not something I’d consider again.
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by Valpo A7 View Post
    Not to mention that your list won't indicate your level of detail and care involved, I suspect more than many dealer mechanics. Always going to be some unknowns . . . .
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
