Results 1 to 9 of 9
    Junior Member One Ring
    Apr 13 2021
    Sussex NJ
    Anyone do any big turbo builds on the B8 A5 2.0T?
    Planning on doing a big turbo build, CTS Boss 600 kit with the garret gtx3071R, on my 2010 A5 and was just wondering if anyone has any pointers or things to look out for. Keeping stock internals for now. I know the rods are the weak link so I'm planning on running a lower tune to keep it around 400-425hp. Doing fueling upgrades such as an AEM 340lph HPFP, IE Port injection manifold with the fuel rail, and 1000cc ev14 injectors(To fill the 4 new port injector slots). It currently has a fully straightpiped 3" exhaust, cold air intake, Front mount intercooler with charge piping, and a Forge BOV. Is there anything else I may need to reach my desired power? Can I get more power safely with stock internals as long as I keep the torque lower? Are there any other shortcomings to reach higher power levels? Sorry for the bombardment of questions lol
    Veteran Member Four Rings RockJGC's Avatar
    Sep 28 2014
    NY/NJ metro area
    Check YouTube for Flink Films. Guy has some really good content on his big turbo A4.
    Veteran Member Four Rings Sgibb16's Avatar
    Jul 02 2012
    2012 A5 & 2002 Passat Wagon
    Fredericksburg, VA
    You wont find a bunch of big turbo build here in the A5 section, there is more of that over in the A4 section (same engine), I've linked one of the more comprehensive build threads that I can recall.
    https://www.audizine.com/forum/showt...ge-2-and-Beyon
    2012 A5 P+ | Sports Package | 6MT | 35% Tint
    REVO Stage II | AWE Quad Exhaust | 034 HFC | E-Codes | FK Silverline Coils | JHM Short Throw Shifter | Eurocode HFIC Pipe | Roc Euro Intake
    TR8 Intercooler | CTS Silicone Hose Kit & Turbo Outlet | CR-15 Strut Brace | Alu Kreuz | S-line Front & Rear Bumper Conversion
    Veteran Member Three Rings apeck240's Avatar
    Apr 01 2021
    I did, you don't need the manifold or port fueling, I have the 340, autotech hpfp and mabo injectors and still have plenty of fuel head room, even at 36 psi but I'm on 93. Working on meth now to be able to run some timing at boost that high
    Apr 01 2021
    If you're not doing internals, the 500 kit is a way better choice, and even that I'd turn down with a stock engine. People like to guess how much the stock rods can handle, but there haven't been enough failures on well set up and tuned cars to really nail down a number
    Veteran Member Three Rings ip428's Avatar
    Jan 01 2015
    B8.5 S4 6MT, B8/.5 A5 6MT, 996 C2 6MT
    ATL
    Quote Originally Posted by RockJGC View Post
    +1, great content, and realistic expectation on what could happen.
    B8.5 S4 6MT - KW V3/JHM/Magnaflow, etc etc
    B8 A5 6MT, SR66 Widebody, Unitronic Stg II+, HPA K04, Etc etc - SOLD
    IG: @infamous_m0
    ACNA Member
    Apr 13 2021
    Sussex NJ
    Quote Originally Posted by apeck240 View Post
    I am going to the internals eventually just not yet. It’s definitely pricey lol. So I don’t want to buy another turbo after I do build it
    - - - Updated - - -
    Thanks I’ll check it out!
    Apr 13 2021
    Sussex NJ
    This is like a stepping stone before I build the internals. Once the internals are done, I’m hoping it’s going to be around 625-650hp at the crank and an rpm range up to 8500-9000. So you’re right I don’t need it right now but I’m just planning ahead with it.
    Dec 30 2019
    charlotte,nc
    IÂ’ve been thinking about the same goals as you for a couple of weeks now. Flink Films is kind of a test subject for a big turbo setup since it there isnÂ’t much gathered data out there.
    IÂ’m looking to make 600ish as well with built internals BUT with the versatility of having variety. By this I mean not using the typical Boss 500-600 but using a custom setup with this flanged.
    https://www.uspmotorsports.com/2.0T-...-Manifold.html
