Originally Posted by
Ven2323
Yeah, I took delivery in January, winter tires were mounted on the factory rims with factory sensors, everything worked perfectly for four months. Installed new wheels/tires/sensors in May, synced right up, no issues. Just doesn't make much sense that the factory wheels/sensors wouldn't re-sync after sitting in my basement for 6 months.
Interesting. Have you driven for an extended period of time or always short trips. Found this blurb in the manual:
If the TPMS indicator light appears after switching
the ignition on or while driving and the (low tire pressure) indicator
light also blinks for approximately one minute
and then stays on, then there is system malfunction.
The following are examples of situations
that could cause a malfunction:
— If the message appears at the end of the adaptation
phase, the system may not detect one or
several of the wheel sensors necessary for pressure
monitoring. This may result from one or
more wheels without wheel sensors or with incompatible
wheel sensors being installed.
The TPMS indicator light and the message turn off
once the tire pressure monitoring system is available
again. If you cannot correct the malfunction
and the TPMS indicator light stays on, drive immediately
to an authorized Audi dealer or authorized
Audi Service Facility to have the malfunction
repaired.
If the changed tire pressures are not displayed
on the MMI, drive the vehicle for approximately
10 minutes so that the sensor signal from the
wheels is received again.
During this adaptation phase, --.-- is displayed
for the pressure and temperature and the tire
pressure monitoring system is only partially
available. It only provides a warning if one or
more tire pressures is below the minimum permitted
specified pressure.
