Background: my B8 A4 has a CEL and is throwing a code which suggests a problem with either the O2 sensors or cat. Went the cheaper route first and replace the O2 sensors but CEL returned shortly thereafter so thinking I may have to replace the cat.
Problems: CO is veering sharply to the left and our governor pushed thru some legislation adopting CA CARB standards for CO starting 1/1/21. A new OEM cat for the car is $1950, but used OEM cats are available, including thru AZ, at much less, like $250. Under CA CARB rules, "...after July 1, 2008, .... no person shall install, sell, offer for sale or advertise any used, recycled, or salvaged catalytic converter in California."
CO has adopted CA rule except, as I read the literal CO language, this rule applies prospectively, only to model years 2022 and later. Interpretive guidance from the CO regulatory agency seems to omit, whether intentionally or ignorantly, the 2022 or later model year qualifier.
My questions are:
-for CA drivers, how is CARB interpreting and enforcing this rule (Section 2222(i)(1)?
-for CO drivers, does or does not the rule apply to pre-2022 models?
-for all, why in the f*ck would regulators object to, or have a rule against, installation of a used OEM cat to replace a defective OEM cat in a an older model car? If it was good enough in 2010, why isn't it good enough now? I sort of understand the prohibition against use of aftermarket cats, unless they are CARB-certified, but used OEM cats? WTF?
