Results 1 to 8 of 8
    Veteran Member Three Rings eightamrock's Avatar
    Jan 21 2016
    Premature Wheel Bearing Failure…
    Just wanted to chronicle my issue should anyone else have similar.
    I am second owner of my B9 RS5. First owner put 3k on the clock and traded in. I purchased and put another 4k on it. So today the car has 7k miles and it has just about never driven right. What does that mean? Let me explain.
    I have spent months trying to diagnose wheel vibrations and humming sounds coming from the front of the car.
    On the stock rims and tires (20” flag rotors and sport contacts), I had the tires rebalanced, an alignment done, and several techs drive the car who said “it’s fine, we don’t feel or hear anything”. Note that the alignment shows that the front left was way out of spec. I think previous owner hit something. So I know that front driver hub is suspicious.
    Frustrating. At the time putting on spacers made the problem a lot worse. Note that these spacers came off my S4 which drove glassy smooth. Audi and an independent shop both said it must be the spacers, but maintained they didn’t feel anything. (This was my first hint it might be the bearings because the problem got worse when the bearings were taking more load from the tires being pushed out a bit, but they, both Audi and the independent shop disagreed) So I started swapping things out because I was very unhappy with it all.
    I decided to swap rims and tires, l figure the stock tires plus maybe the previous owner having hit a pothole or 2 was probably the issue. After all the front left was really misaligned the first time it went on the machine. I suspect it’s a bent rim or maybe the bearing.
    I bought a set of 19” RS wheels and brand new AS/3+ tires. The rims were ET25 so they actually achieved the offset I was looking for without spacers and I sized down because of the good old NJ roads.
    For the first few days it seemed better. Not great but better. After a week I started getting vibrations again. What was worse was that humming actually got louder at exactly 81 MPH. Perfectly reproducible. Front left. At this point I’ve been through 2 sets of wheels and tires, spacers and no spacers….and it’s still there. I’m convinced it’s the bearings or the drive shaft.
    Took it back to the shop. “Car is fine, it’s just tire noise”. I asked them about the vibration. They didn’t feel it. I then asked if they drove it at the speeds I asked, they said their tech couldn’t do that. FFS.
    A few weeks go by, it’s really annoying me. Took it to the shop again and asked them to balance and align the tires again, they do it. Rebalanced 2 wheels and aligned it, and said it was fine.
    Next trip to work. 81 MPH hummmmmmmmmmmmm. Front left. Every time. Exacerbated, took it back to the independent shop a few weeks later and asked them to take it home for the night. Push it around and listen. I’m convinced it’s the wheel bearings.
    The next day they called and said. Yeah we heard it. FINALLY! I’m not crazy. They continue to say they also felt the vibration in the wheel I’ve been complaining about. They agree to do some more digging. They spend about 3 hours using chassis listeners and spinning it up to 81 on the lift. No noise. They can’t determine where it’s coming from. The next thing they recommended was taking it back to Audi and having them pull the trans under warranty to take a look. They think it’s the drive shaft.
    Now at this point I’m still convinced it’s the wheel bearing.
    1. Spacers made it worse.
    2. No noise spinning it up on the lift? Well there’s no pressure on the bearing
    3. Wheels and tires have been swapped twice. The only other part is the bearings or drive shaft.
    4. Front left had obvious signs of impact. First alignment was way out.
    I asked them to change the bearings. They were very reluctant to just throw parts at it, but I convinced them (I mean I had to pay, but Audi was never going to replace them because they couldn’t reproduce the issue) They, along with Audi, said “this isn’t what a bad bearing sounds like” but they are right. It is not the traditional way a bearing fails, but all things pointed to the bearings.
    Got it back yesterday. Car drives like it’s on glass. Zero vibration, zero humming. Almost 6 months of heartache for the thing I said it was to start.
    So if you are fighting with in and out vibration in the wheel or any humming noise….. check the bearings. I’ll update here if it comes back, but the car has never driven as smooth and quietly at highway speeds as it did today and I pushed it around for a few hours to be sure.
    '19 Daytona Gray RS5 Sportback
    Options: B&O Sound, Dynamic, Navigation, Black Optic, RS Driver Assist, RS Stitching
    Mods: Suntek PPF wrap
    Senior Member Three Rings dal59's Avatar
    Mar 31 2021
    2021 RS5 - 2022 BMW X3 - 2002 Harley Wide Glide
    atlanta
    First of all, after all of that, I am so very pleased to hear you finally have gotten it resolved and now have the car you always should have had.
    I went through a lesser, but similar situation with bent wheels and flat spots on brand new factory tires. However, when Audi was checking all that out for me, they decided to check the wheel bearings just to be sure. They wound up replacing the two front bearings after listening to them up on the lift. They said they were not bad enough to cause the vibration, but they were already making noise at approx. 3,000 miles and said it was just a matter of time, so they replaced them.
    They also told me they thought the factory had gotten a bad batch of bearings as they had been replacing a lot of them on low mileage cars.
    Again, glad you are all straightened out. Enjoy!!!!
    Jan 21 2016
    Quote Originally Posted by dal59 View Post
    We should compare build dates and locations.
    Veteran Member Three Rings ywang98's Avatar
    Nov 02 2018
    Orange County, California
    On my old VW Rabbit, I had the same symptoms. I knew it was the bearing. I replaced both fronts myself back in the days. And that fixed it.
    Apr 06 2021
    New York
    I also have a bearing issue at 18k miles. Both front bearings make an awful, loud, embarrassing metallic creaking and popping sound whenever I turn in either direction. Initially dealership told me nothing is wrong/could not replicate. Then they repaired one of the bearings but the issue has since came back even worse. They finally ordered new bearings for both sides and will be replacing them next week under warranty. While I appreciate the free repair, this has been an issue since I bought the car at 6k miles and I wish it was resolved earlier.
    2019 RS5 - Daytona Grey, APR 93
    2016 VW GTI - White, 6MT
    ----gone----
    2005 VW Passat GLS
    2006 Passat VR6
    2013 Subaru Forester, 5MT
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    https://www.carcomplaints.com/Audi/A...047920-5.shtml
    There's been a TSB out for B9 wheel bearing issues for a while now - one above references A4 and A5. I have an 2017 A4, not A5/S5 but had both my front bearings replaced under warranty in Mar, 2021. My mileage was 29,000 km (~18,000 mi). Symptom in my case sounded like a loud computer fan (buzzing noise) coming from the instrument cluster/steering column area. These cars are quiet, so I'd suggest getting Audi service techs to listen anytime you hear "additional noise". In my case, the tech said using a stethoscope while driving on a hoist helped identify the bearing noise. FWIW, from my service record both old bearing part numbers were 8W0 407 625L, no indication what the replacement part number is.
    Senior Member Two Rings IamRacer X's Avatar
    Sep 26 2019
    Jupiter, FL
    Since new my car has made friction noises after the car has gotten wet and dried (washing mainly) when I turn sharply. It goes away after a handful of miles driven. Sometimes it is worse though and I can hear it when driving straight. I have also always(since new) had a friction noise at full lock when making a U- turn... anytime. I wrote it off as being part of the AWD noises. I'm due for my 2 year service, I'll have the dealership check it out.... not that I think they will notice anything, plus if they might Im sure they will blame my wheel spacers.
    Current
    2019 RS5 Sportback Nardo
    Original Owner
    2003 Corvette Z06
    LS3, Coilovers, BBK, Track/Street
    2022 Jeep Wrangler
    High Altitude
    Jan 21 2016
    Quote Originally Posted by IamRacer X View Post
    Friction noise is a good way to describe it, also the TSB above with the "computer fan noise" I guess, definitely a humming.
    My car definitely doesnt feel like its dragging anymore, and I gained about 3-4 MPG on my commute. I also noticed that my front left wheel was always 4-6 degrees warmer than all the other ones, which would make sense if there was a friction issue in the bearing and it as transferring heat to the rim or if the wheel was wobbling a bit and heating up from increased road friction. Post fix all wheels are the same temps.
