Sorry if this has been asked before! did use the search feature just didnt find anything concrete
Code:
Thursday,23,September,2021,16:02:42:64766 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 21.9.0.2 (x64) HEX-V2 CB: 0.4555.4 Data version: 20210903 DS330.0 www.Ross-Tech.com VIN: WAUFFAFL9CN016282 License Plate: Chassis Type: FL-AU48 (8T0) Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 52 53 55 56 5F 62 6C 72 VIN: WAUFFAFL9CN016282 Mileage: 352450km-219002miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (0-----CAEB) Labels:| 06H-907-115-CAB.clb Part No SW: 8K2 907 115 AG HW: 8K2 907 115 D Component: 2.0l R4/4V TF H20 0002 Revision: E1H20--- CVN: 8129BB47 Coding: 0104010A290F0160 Shop #: WSC 82976 802 690857 ASAM Dataset: EV_ECM20TFS0118K2907115AG 001002 ROD: EV_ECM20TFS0118K2907115AG.rod VCID: 74B1DE165E34E04BB39-8020 VINID: 9D195659159C25378004608808322FE670 No fault code found. Readiness: 1110 0100 ------------------------------------------------------------------------------- Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb Part No SW: 8K0 927 158 S HW: 0BK 927 156 R Component: 0BK 20TFSIUSA H08 1003 Revision: --H08--- CVN: E30475B4 Coding: 000002 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_TCMAL551211 002018 ROD: EV_TCMAL551211_002_AU48.rod VCID: 46D554DE782822DBDDD-8012 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ Component: ESP8 quattro H04 0060 Revision: -------- Serial number: -------------- Coding: 1D0D18 Shop #: WSC 02391 823 56573 VCID: 025D88CE1400DEFBB15-8056 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF Component: BCM2 2.0 H05 0435 Revision: 00002001 Coding: 090100 Shop #: WSC 02399 823 56573 VCID: 76B5E41E48C8F25B8DD-8022 Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A Component: FBSAUDIB8 IDG H60 0072 Serial number: 0511000069440011 Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D Component: J764 ELV MLB H37 0042 Serial number: 2311000245218014 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ Component: KLIMA 3 ZONEN H08 0180 Revision: C1000000 Serial number: 01101120110207 Coding: 64102000 Shop #: WSC 02391 823 56573 VCID: 005982C61A0CCCEBA71-8054 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb Part No SW: 8K0 907 063 P HW: 8K0 907 063 P Component: BCM1 1.0 H30 0392 Revision: 10030001 Serial number: 00000001128970 Coding: 26001091063CAF010000080300003D0D0F1C520802010161000000 Shop #: WSC 02391 823 56573 VCID: 3C2136363664680BBB9-8068 Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 131111 H07 0070 Serial number: SWF11110135714 Coding: 00FD11 Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB Component: RLS H04 0003 Serial number: 11781182 Coding: 025028 Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS Component: E1 - LDS H03 0031 Serial number: 00000000000411110223 Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C Component: HOMELINK H01 0010 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb Part No SW: 8K0 919 475 T HW: 8P0 919 475 M Component: PARKHILFE 4K H01 0081 Revision: 11001001 Serial number: 36861129800135 Coding: 200103 Shop #: WSC 02391 823 56573 VCID: 4ACD60EE6CB0C6BB395-801E No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 8K0-959-655.clb Part No SW: 8K0 959 655 K HW: 8K0 959 655 K Component: AirbagVW-AU10 H44 0610 Serial number: 003GLD0PBP7Z Coding: 303837354230303030304A55304C384B3053 Shop #: WSC 02135 785 00200 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_003_AU48.rod VCID: 45D753D2452E29C3D47-8010 Seat occupied recognition: Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C Component: BF-Gewichtss. H02 0040 Serial number: 5810000R1100007FLM Crash sensor for side airbag: driver side: Serial number: 6334MSME67120C438 Front Passenger's Side Airbag Crash Sensor: Serial number: 6344MSME66112C147 Rear Side Airbag Crash Sensor (on driver's side): Serial number: 6352QSME39641F52M Passenger side rear thorax airbag crash sensor: Serial number: 6362QSME016523487 Crash sensor for front airbag: driver side: Serial number: 63732SME71640E54/ Crash sensor for front airbag: front passenger side: Serial number: 63832SME1266317E/ No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb Part No SW: 8K0 953 568 F HW: 8K0 953 568 F Component: Lenks.Modul H17 0014 Revision: -------- Serial number: 90372KK8001CT Coding: 000016 Shop #: WSC 02391 823 56573 VCID: 3D273B322D7E61038C7-8068 Component: E221 - MFL H02 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb Part No SW: 8K0 920 981 C HW: 8K0 920 981 C Component: KOMBIINSTR. H31 0261 Revision: 00000000 Serial number: NW560CX3E Coding: 8B1609000300D705020000 Shop #: WSC 57489 000 1048576 VCID: 33331D0A1B3AA7736A3-8066 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb Part No SW: 8T0 907 468 AH HW: 8T0 907 468 K Component: GW-BEM 4CAN-M H09 0120 Revision: EC101057 Serial number: 5700E11A318397 Coding: 00C303 Shop #: WSC 02391 823 56573 VCID: 074B99DA3F22FBD3E6B-8052 Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181 Component: J367-BDMHella H03 8040 Serial number: 1830876001 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb Part No SW: 8K0 959 760 D HW: 8K0 959 760 D Component: MEM-FS H06 0076 Revision: AA000000 Serial number: 00000017588607 Coding: 00581300000000000000 Shop #: WSC 02391 823 56573 VCID: 3B23352A336A6F33B23-806E No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb Part No SW: 8T0 959 793 M HW: 8T0 959 793 D Component: TSG FA H08 1501 Revision: -------- Serial number: -------------- Coding: 011C03204E00410001 Shop #: WSC 02391 823 56573 VCID: 53F37D8ABBFA87734A3-8006 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF Component: BCM2 2.0 H05 0435 Revision: 00002001 Serial number: 0163292145 Coding: 0106063A00FA440480B0013200000000 Shop #: WSC 02391 823 56573 VCID: 76B5E41E48C8F25B8DD-8022 Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719 Component: GTO BF H01 0070 Serial number: 00000000000000459071 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591 Component: J245 PS050 H08 0043 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb Part No SW: 8T0 959 792 M HW: 8T0 959 792 D Component: TSG BF H08 1501 Revision: -------- Serial number: -------------- Coding: 011C03204E00410001 Shop #: WSC 02391 823 56573 VCID: 52FD788E84E08E7B415-8006 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb Part No SW: 8K0 907 801 H HW: 8K0 907 801 H Component: EPB Audi B8 H09 0100 Revision: 00000003 Serial number: 10000000870594 Shop #: WSC 00000 000 00000 VCID: 34311E161E34A04B739-8060 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb Part No SW: 4H0 907 357 B HW: 4H0 907 357 B Component: ....LWR12.... H02 0010 Serial number: 111116-0002-112 Coding: 1171A41010020400 Shop #: WSC 02145 785 00200 ASAM Dataset: EV_HeadlRegulBasic 005001 ROD: EV_HeadlRegulBasic_AU21.rod VCID: 2D070B72FD9EF1833C7-8078 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels:. 4F0-035-0xx-56.clb Part No SW: 4G0 035 082 B HW: 4G0 035 082 Component: Radio U SIRIU H53 0076 Revision: AB001007 Serial number: 156K60B7574682 Coding: 020007020100000001 Shop #: WSC 02391 823 56573 VCID: 1F1BE1BA87B21313BEB-804A 3 Faults Found: 00417 - Left Front DSP Mid-Bass Speaker (R101) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 5 Fault Frequency: 1 Reset counter: 176 Mileage: 352450 km Time Indication: 0 Date: 2021.09.23 Time: 16:59:09 Freeze Frame: Voltage: 11.80 V 00417 - Left Front DSP Mid-Bass Speaker (R101) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 5 Fault Frequency: 2 Reset counter: 136 Mileage: 352450 km Time Indication: 0 Date: 2021.09.23 Time: 16:59:09 Freeze Frame: Voltage: 11.80 V 03029 - Subwoofer (R157) 006 - Short to Plus Freeze Frame: Fault Status: 01100110 Fault Priority: 5 Fault Frequency: 1 Reset counter: 136 Mileage: 352450 km Time Indication: 0 Date: 2021.09.23 Time: 16:59:12 Freeze Frame: Voltage: 11.80 V ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb Part No SW: 8T1 035 664 D HW: 8T1 035 664 B Component: H-BN-NA H52 0165 Revision: -------- Serial number: 490K30B7650675 Coding: 010200000006A1EF41000B0E000000030000 Shop #: WSC 02391 823 56573 VCID: 392F2F2239565D23A0F-806C Subsystem 1 - Part No: 8R0 060 884 AD Component: NAR 2011 0505 Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604 Component: DU7 High H41 0104 Serial number: A130J10BS042630 Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F Component: E0380 Bedient H08 0100 Serial number: 00000000989058 Subsystem 4 - Part No: 8R0 060 961 A Component: CD-Database 2712 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb Part No SW: 8T0 959 795 N HW: 8T0 959 795 B Component: TSG HL H06 1501 Revision: -------- Serial number: -------------- Coding: 010C03204000210001 Shop #: WSC 02391 823 56573 VCID: 56F5849EA808925BADD-8002 No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 8T0-907-441.clb Part No SW: 8T0 907 441 C HW: 4L0 907 441 B Component: J772__Rearview 0040 Revision: --H05--- Serial number: 525PA8-J1X95FZ Coding: 1000006 Shop #: WSC 02391 785 00200 VCID: 38292A260E5C442B5F1-806C No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb Part No SW: 8T0 959 795 N HW: 8T0 959 795 B Component: TSG HR H06 1501 Revision: -------- Serial number: -------------- Coding: 010C03204000210001 Shop #: WSC 02391 823 56573 VCID: 56F5849EA808925BADD-8002 No fault code found. End----------(Elapsed Time: 01:45, VBatt start/end: 13.1V/14.0V)-----------
