Hi!
First of all, sorry for also posting here, as the car in mention is a standard A4, but people with S4/RS4 versions might be able to help me more.
I've got a 2001 B5 A4 Avant under my hands, that I need to retrofit a factory rear parking sensor into.
I have the sensors, the "parking module", the speaker and all the wiring. They are already in place, but I couldn't find info anywhere about the wiring.
There are six wires at the end of the loom coming from the module, for reverse signal, k-line, speed sensor, etc. The ground for the whole thing is a separate wire that doesn't count towards the 6 I mentioned.
I have no idea which cable is which on the module as the colors of the cables do not match up with the colors on the car.
It is my understanding that this is an exceedingly rare equipment for these cars, mostly (maybe only) found on the S4 and RS4 models.
Have any of you did this retrofit already, or has this factory system installed in your car?
