Results 1 to 22 of 22
    Veteran Member Three Rings socialpro's Avatar
    Sep 26 2013
    2023 RS6 || 2022 XC60
    scottsdale, az
    SQ5 Brakes - Rotor and Pads replacement !!! Necessary to change out rotors?
    Recently had my 2019 SQ5 in for 40K service at audi and recommendation was to replace both front AND rear rotors and pads. Pads have 2mm rear, 4mm front (no sensors have been tripped yet). Neither have been yet changed on this car (lots of freeway driving).
    Trying to figure out what to do - and if it's necessary to be changing BOTH FRONT AND REAR ROTORS out as well at 40K. What have you done ? Dealer wants $2500+ for entire swap.
    Thanks guys!!
    Junior Member One Ring
    Jul 10 2019
    Greenville, SC
    The rotors on our cars typically need to be changed as part of the brake service. I recommend looking for a local independent Audi mechanic for the brakes. I received a similar quote on my 2018 SQ5, ended up getting the rears changed for $500 including rotors and the indy shop using OEM parts. Fronts are quoted at $600 ish, and the shop recommends that i drive until the sensor is tripped before servicing.
    Sep 22 2011
    Western MA
    If your brakes aren’t thumping due to warping theoretically you can change just the pads. In reality what ends up happening unless you have access to a brake lathe you can cut the rusty lips off you will end up with thumping brakes in 10K or 15K miles or less. At which point you can buy all and start over.
    If you can change out the parts yourself it costs hundreds not thousands. Get Zimmermann rotors, FCP Euro now has them.
    2020 SQ5 Ibis White
    2016 A3 Cabriolet Glacier White 2.0T
    2011 Q5 Ibis White 2.0T (sold)
    2008 A4 Cabriolet Ibis White 2.0TQ (sold)
    2000 A4 Laser Red 1.8TQM (sold)
    Veteran Member Three Rings 4-ring-sleepers's Avatar
    Feb 17 2018
    2018 SQ5/2021 SQ8
    Central FLorida
    I drove with the brake light (pads) warning in mmi for like 5 months before i ever heard any metal on metal type sounds. If no mmi message wait till that pops up to change. Especially if they are selling you pads and rotors at 40k miles Resized_20201210_122050.jpg
    2018 SQ5 Prestige - AWE Carbon Intake, AWE Touring Resonated Exhaust, RedStar Exhaust HFC Downpipe, Turbo Systems Stage1 Hybrid Turbo, Forge Motorsports FMIC, Forge Motorsports Transmission Insert, Cete Active Suspension Controller, EPL Stage 3 (beta) tune, Carbon Fiber (w/alcantara sides) Steering Wheel, Vorstiener VFF-110 20x9 et35 Zara Gray, APR 10mm Spacers, Ti extended Lugbolts, Suntek Ultra PPF, Cquartz Finest Reserve, Full Cquartz Interior, Formula One Stratos Tint 30%
    Feb 17 2018
    2018 SQ5/2021 SQ8
    Central FLorida
    I went with R1 concepts F/R carbon geomet drilled rotors and hawk hps500 pads vs oem and i had 35k miles when i finally changed them
    Sep 22 2011
    Western MA
    I try to keep an eye on pad thickness so I can reuse the sensor usually with out even disconnecting it.
    2020 SQ5 Ibis White
    Veteran Member Four Rings audirings4's Avatar
    Nov 23 2011
    SQ7
    DFW
    Threads like this make me glad I do my own maintenance. I would end up paying one fourth of that quote.
    Junior Member Two Rings BrisAudi's Avatar
    Oct 16 2018
    Brisbane AUS
    Quote Originally Posted by 4-ring-sleepers View Post
    What size are the fronts Eric? They don't list the front one as available for our SQ5. The only have the rear on their website.
    Feb 17 2018
    2018 SQ5/2021 SQ8
    Central FLorida
    Quote Originally Posted by BrisAudi View Post
    You have to email them directly. They are oem size if/when available.
    Veteran Member Four Rings rcprato's Avatar
    Jan 30 2018
    21 Jeep Grand Cherokee Overland
    Rochester, NY
    I think dealer service departments push brake jobs because it’s an easy sell “OMG my brakes are worn out” for a lot of people.
    I wait until sensor turns on and always replace rotors, pads and sensors when doing the brake job.
    Junior Member Two Rings jamessteel's Avatar
    Jan 08 2019
    Chicago
    Can I put in front the Power Stop K8043 - Power Stop Z23 Evolution Sport Brake Upgrade Kit
    and then in the back put rotors Power Stop EBR1209EVC vents but solid ?
    or is better match both front and back?
    Nov 04 2021
    Georgia
    I just bought 2018 w/28k on it rear needed replace, but not the front dealer wanted $888 rotor and pads….I went ahead and got R1 format and rear w/their ceramic pads for under $600 and then had em installed at local shop for $200….so I still paid less than only the rears form dealer….total rip off
    Mar 09 2023
    New York
    2018 Audi Q5 premium plus Front Break pads
    Do you know how to replace the 2018 Q5 front break pads?
    Established Member Two Rings SurfTek's Avatar
    Oct 18 2019
    Virginia
    Stevens Track days on YouTube has a video for front and another for rear. He even lists all tools and torque specs. It’s for B9 S4 but SQ5 is the exact same. I just did mine with R1 rotors and pads and saved $560 in labor.
    2018 ▊ SQ5 - Prestige | Florett Metallic Silver
    Jul 13 2018
    Winnipeg, MB, Canada
    While on the topic of brakes, my new to me 2019 SQ5 requires a surprising amount of leg effort to stop and the pedal is quite hard. I wish there was more initial bite Could it be the pads are just glazed or rusty? Based on low mileage, every component should be stock. Car sat at the dealer for a long time.
    Jan 30 2018
    Rochester, NY
    I have a 18 SQ5 and the brake pedal is firm to push but the initial bite of the pads is strong and stopping power very linear all the way to complete stop.
    At 46K now and have replaced rear rotors and pads with Brembo rotors and current Rev OEM pads.
    Veteran Member Three Rings mrmeth90's Avatar
    Jun 29 2007
    Miami
    Do you need to replace the clips when changing the brake pads?
    2008 A4 2.0tQ Phantom Black Titanium-APR Stage 2+ --AWE Quad Tip Black Diamond Exhaust--GSG FMIC--GSG CAI--Labree HFC--APR Snub--AWE Boost Gauge--Xenon Retrofit/Blacked out housing/CC Mod--Painted front and rear Reflectors--Lamin-X Tails--ZiZa Pure Yellow Fogs--H&R Coilovers--H&R Rear Sway Bar--
    Next Mods:
    APR HPFP, LED Taillights, BBK (not sure brembo or stoptech) Carbon Fiber Trim, Recaro Seats...
    Jan 30 2018
    Rochester, NY
    Came with brake pads I bought when I did brakes
    Jun 29 2007
    Miami
    Quote Originally Posted by rcprato View Post
    Which pads did you get
    Next Mods:
    Jan 30 2018
    Rochester, NY
    OEM back and Ferodo front pads from here https://www.germanautoparts.com/cata...-Brake.Pad.Set
    Ferodo is manufacturer of rear OEM but at time Audi branded front pads were not available
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Fcpeuro, lifetime parts replacement. Just buy them once and your subsequent sets are reimbursed after returning the used brakes.
    My rears went at around 25k, fronts are still going strong at 28k. Not sure why my rears wear faster though.
    I used a mobile brake service by me. Quoted about $200 in parts and $250 in labor. Insurance reimbursed for my rotors since I have mechanical breakdown insurance.
    -cW
    2023 X3 M40i Alpine White
    Jul 13 2018
    Quote Originally Posted by TheContrarian View Post
    I have a hard brake pedal in the morning now, so I probably have the check valve issue. But does this reduce the power assistance in general when driving? I still find the brakes pretty weak, even when applying some serious leg effort. Certainly the braking doesn't feel consistent with the huge calipers.
